Using GPUs with UDFs
Old   December 29, 2011, 01:50
Default Using GPUs with UDFs
TMac is on a distinguished road
I just read in the release notes that fluent now supports using GPUs in UDFs, but the beta documentation does not have any example. Have someone here used it already?
"Enable FLUENT UDFs to execute on GPUS (beta feature)" page 81
TMac is offline   Reply With Quote
Old   January 11, 2013, 13:24
Ernesto
epc1 is on a distinguished road
Hello i found this:
"UDFs can be compiled in ANSYS FLUENT with OpenCL support for execution on General Purpose Graphics Processing Units (GPGPUs) on lnamd64 and win64 platforms. To enable OpenCL support, you should use the following text user interface (TUI) command: /define/user-defined/enable-udf-on-gpu before compiling the UDF. The UDF library is linked with libOpenCL.so on lnamd64 and OpenCL.dll on win64. For execution on GPU systems, the appropriate environment variable (LD_LIBRARY_PATH on lnamd64 or %path% on win64) should be correctly set so that libOpenCL.so/OpenCL.dll is loaded along with the UDF library."
Can anyone help on how to define the appropiate variable so that it would work?
epc1 is offline   Reply With Quote
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 05:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 18:18
Unsteady and Flux UDFs for UDSs tom FLUENT 0 February 13, 2009 11:27
How to use more than one UDFS in one problem Thanh FLUENT 2 August 13, 2008 22:28
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 16:36
