UDF for Transirion SST model
Old   December 21, 2011, 11:01
Default UDF for Transirion SST model
H.A
sifou is on a distinguished road
When using th Transition SST turbulence model, it is possible to introduce, in the form of UDF, new correlations (user correlations) for Re_theta, Flength and Re_theta_c .
The two last correlations are function of the local transition Re_theta_tild, obtained from a transport equation.
I need to know how to access the values of this parameter (Re_theta_tild).
Thanks.
sifou is offline   Reply With Quote
Old   June 29, 2015, 03:56
Zhiwei Zheng
killsecond is on a distinguished road
Originally Posted by sifou View Post
Thanks.
I have the same problem, have you solved it?
killsecond is offline   Reply With Quote
Old   April 28, 2024, 09:04
Kamyar
kam96 is on a distinguished road
Same problem over here and I'll be glad if any of you guys have found any solution for this, the only probable solution that I've found is to define the two retheta and intermittency equations as UDS but it's probably not that efficient.
kam96 is offline   Reply With Quote
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
convergence problem of the SST and RNG k-e model for mixing tank ziyan7 FLUENT 0 March 8, 2011 07:13
UDF for linear PTT model implementation dpitz Fluent UDF and Scheme Programming 1 February 4, 2011 11:08
Understanding k-omega SST model source code tmhonka OpenFOAM Programming & Development 1 September 8, 2009 08:33
UDF in Re stress model Jihwan FLUENT 0 February 28, 2007 04:49
