November 29, 2011, 14:56 |
Please Help me with Scheme
TiffanyGirl
1.
Describe the worst-case asymptotic running time of the all-positive? Scheme procedure defined below (from the Exam 1 comments). You may assume that all elements of p have values below some bound k, so the running time of > is constant. Remember to clearly define all variables you use in your answer. (define (all-positive? p) (if (null? p) true ; reached end without finding non-positive, so result is true (if (> (car lst) 0) (all-positive? (cdr lst)) ; keep looking false))) ; found one non-positive 2. Define a Scheme procedure make-cumulative! that takes as input a mutable list, and modifies the list so that each element is the cumulative total of all elements up to and including itself. For example,  >(define p (mlist 1 2 3 4 5)) >(make-cumulative! p) >p {1 3 6 10 15} Also, what is the asymptotic running time of your make-cumulative! procedure. You should not assume the running time of the + procedure is constant; instead, assume that its running time is linear in the size (number of bits) of its inputs. Thank you all soo much. Love, Tiffany xxxoooxx |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 13:29 |
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 22:20 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 02:50 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 12:08 |
extrapolation in MUSCL scheme | Chandra | Main CFD Forum | 6 | February 14, 2007 12:21 |
