May 21, 2014, 12:04 |
#21 |
Rep Power: 16 |
Hi Ignacio,
I think, you have some problem with your code… If you do not mind, you can send me the code and I can check it. kah.recep@gmail.com best regards, |
May 21, 2014, 21:47 |
#22 |
Rep Power: 14 |
Hi Kanarya:
I applied the modifications to the code you recommended to me, but I'm still getting the same error messages: Updating solution at time level N... done. iter continuity u-aire u-solidos v-aire v-solidos gt-solidos k epsilon vf-solidos time/iter # Divergence detected in AMG solver: mp-x-momentum -> Decreasing coarsening group size! # Divergence detected in AMG solver: mp-x-momentum -> Increasing relaxation sweeps! # Divergence detected in AMG solver: pressure correction -> Turning off correction scaling! Divergence detected in AMG solver: pressure correction Divergence detected in AMG solver: k Divergence detected in AMG solver: epsilon Divergence detected in AMG solver: vof-1 Divergence detected in AMG solver: pressure correction Divergence detected in AMG solver: k Divergence detected in AMG solver: epsilon Divergence detected in AMG solver: vof-1 Divergence detected in AMG solver: pressure correction Divergence detected in AMG solver: k Divergence detected in AMG solver: epsilon Divergence detected in AMG solver: vof-1 Divergence detected in AMG solver: pressure correction Divergence detected in AMG solver: k Divergence detected in AMG solver: epsilon Divergence detected in AMG solver: vof-1# Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps! Primitive Error at Node 0: floating point exception Primitive Error at Node 1: floating point exception Primitive Error at Node 2: floating point exception Primitive Error at Node 3: floating point exception Error: floating point exception Error Object: #f I'm using a non-uniform grid in radial direction, and thinking that this could be a problem, I returned to a radial uniform grid, but I got the same error messages for the uniform grid case. Then I changed the UDF drag model to modified Syamlal-O'Brien as wrttien in the Fluent UDF manual example and the case start and continue running properly without any error messages, so I'm sure the problem is the EMMS UDF drag model. Any help is very welcome Regards, Ignacio |
May 24, 2014, 14:01 |
#23 |
Rep Power: 14 |
Dear all, finally I found what is the problem. According many papers the initial conditions for riser simulations are setting as Vg=0.0, Vs=0.0, so when the run starts, the Reynold number becomes 0.0, and Cd becomes no-definded, and then the run crashes.
In fact my EMMS UDF drag function commented by Kanarya, including some minor modifications done by myself is working properly. Now I defined initial Vg as 1e-6, and the case is able to start doing 2 iterations, now my problem is flow reversal detected in pressure outlet, but I think i'm walking in the right direction. Regards, Ignacio |
June 2, 2014, 16:53 |
#24 |
Rep Power: 14 |
Dear all:
Finally I found the problem, my EMMS drag model code was not correct, be careful about writing the code properly, and be careful about the if's and else if's statements. Thanks again Kanarya. Good luck doing CFD simulations. Regards, Ignacio |
July 18, 2014, 07:21 |
#25 |
Rajani Kant Baro
Can You tell me how to solve the non-linear equations in variables a & Usc?
January 7, 2015, 06:32 |
EMMS DRAG MODEL for gas solid flow
#26 |
sourav ganguli
Can anyone tell me the operating condition to run emms drag model?
November 19, 2017, 08:49 |
#27 | |
Rakhim
Rep Power: 9 |
I have pretty much similar problem. When I incorporate udf (I modified Symlal model which is provided in the fluent manual), divergence problem occured. My udf (attached below) is modifying drag coefficient between 2 phases in multiphase flow. Could you please have a look? #include "udf.h" #define diamrbc 5.5e-6 DEFINE_EXCHANGE_PROPERTY(custom_drag, cell, mix_thread, s_col, f_col) { Thread *thread_p, *thread_rbc; real u_vel_p, u_vel_rbc, v_vel_p, v_vel_rbc, w_vel_p, w_vel_rbc, abs_vrbc, rho_rbc, mu_p, reyrbc, cd_rbc; /* find the threads for the plasma (primary) */ /* and rbc (secondary phases) */ thread_p = THREAD_SUB_THREAD(mix_thread, s_col);/* plasma*/ thread_rbc = THREAD_SUB_THREAD(mix_thread, f_col);/* rbc*/ /* find phase velocities and properties*/ u_vel_p = C_U(cell, thread_p); v_vel_p = C_V(cell, thread_p); w_vel_p = C_W(cell, thread_p); u_vel_rbc = C_U(cell, thread_rbc); v_vel_rbc = C_V(cell, thread_rbc); w_vel_rbc = C_W(cell, thread_rbc); rho_rbc = C_R(cell, thread_rbc); mu_p = C_MU_L(cell, thread_p); /*compute velocity*/ abs_vrbc = sqrt(pow(u_vel_p - u_vel_rbc, 2) + pow(v_vel_p - v_vel_rbc, 2) + pow(w_vel_p - w_vel_rbc, 2)); /*compute Reynolds number*/ reyrbc = rho_rbc*abs_vrbc*diamrbc / mu_p; /*compute drag and return drag coeff, k_g_s*/ cd_rbc = 5.847e-05*pow(reyrbc, 2) - 0.02132*reyrbc + 1.904; return cd_rbc; } |
emms, udf |
one-step simulation for two-stage model with UDF | wlt_1985 | FLUENT | 0 | March 25, 2011 06:01 |
UDF for linear PTT model implementation | dpitz | Fluent UDF and Scheme Programming | 1 | February 4, 2011 11:08 |
Problem with UDF (Drag model) | understate | FLUENT | 0 | January 4, 2011 06:01 |
UDF for Herschel-Bulkely model | emad | Fluent UDF and Scheme Programming | 5 | July 20, 2009 09:16 |
UDF, Herschel-Bulkely model don't have Yielding viscosity term | emad | Fluent UDF and Scheme Programming | 0 | May 19, 2009 13:46 |
