Cannot use more than 1 UDF at the same time ? |
November 20, 2011, 09:57 |
Rep Power: 15 |
I write UDF, interpret it, hook it, everything works fine.
Than i interpret another UDF in the same case and 1st one disappear. They can be same type or different type, it always does that. When I interpret an UDF, the one i had interpreted disappear. Which is pretty problematic since i need UDF to set my boundary conditions and to initialize my flow field. Is that a problem with FLUENT or am I doing something wrong? |
November 20, 2011, 10:09 |
Rep Power: 15 |
November 20, 2011, 10:14 |
#4 | |
Bests,
Amir |
November 20, 2011, 10:20 |
#5 | |
Rep Power: 15 |
By compiler you mean that i cannot write them in .txt but I need complier such as QT? |
November 20, 2011, 10:31 |
#6 | |
Bests,
Amir |
November 20, 2011, 10:37 |
Rep Power: 15 |
Thank you very much, you helped me a lot !
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 10:15 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
Availability of previous time level values in UDF | ranga sudarsan | FLUENT | 0 | September 1, 2008 10:17 |
