Compiling UDF in Ansys Fluent12
Old   October 3, 2011, 11:24
Default Compiling UDF in Ansys Fluent12
Vishu
Vishu is on a distinguished road
I have problem in compiling UDF in ANSYS FLUENT.
I have installed Visual studio in
C:\Program Files\Microsoft Visual Studio 9.0
My ansys fluent is intalled inside C:\Program Files.
The error it is showing while loading is :
open_udf_library: The file is not specified
Please anyone help me how to get out of this problem.I am using 32-bit system with Windows XP.
the problem might be setting of environment variables.If so kindly let me know how to set them.What path I need to give.
Vishu is offline   Reply With Quote
Old   October 5, 2011, 02:36
Jack cosby
3DmaniacSLDWRKS is on a distinguished road
Do you start fluent from the visual studio command prompt?type in fluent.exe 2ddp(put in 3d or 3ddp .... depending on your case).
to set the env. variables start>fluent>set enviromental variables. this adds fluent to system path, then http://www.cfd-online.com/Forums/blo...fluent-vc.html
remember to run fluent from v.s command prompt
3DmaniacSLDWRKS is offline   Reply With Quote
Old   October 5, 2011, 10:09
Amir's Avatar
Amir
Amir is on a distinguished road
Dear Jack,
I want to clear these 2 different methods for linking (for both, you need to add FLUENT to path):
1) If you want to launch FLUENT from VC++ command prompt, you won't need to set other parameters which I told in my blog; this method is not permanent and consequently, you need to launch FLUENT by VC++ when ever you need UDF compilation.
2) If you've added VC++ variables to your path, you don't need to launch FLUENT from command prompt, when you start FLUENT normally, you can compile your UDF.
Bests,
Amir
Amir is offline   Reply With Quote
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) Ali.beh Fluent UDF and Scheme Programming 3 August 27, 2018 05:22
my problem wuth UDF compiling m.beh FLUENT 3 November 22, 2011 01:47
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
compiling linked udf (C/fortran mixed) bawfuls Fluent UDF and Scheme Programming 0 July 13, 2010 17:53
udf compiling problem akr FLUENT 3 August 22, 2007 08:14
