How to convert my UDF to parallel?
Old   September 12, 2011, 06:37
Default How to convert my UDF to parallel?
Thomas
lapin_tout_fou is on a distinguished road
I wrote a UDF but don't know exatly how to parallelize it.
I should use some PRF_GRSUM1 or PRF_GRSUM2 but I don't know how exactly.
Here is my serial UDF:
#include "udf.h"
#define tension 40
#define rtotal 1000000
FILE *fout;
real intensity;
real r1,r2;
real p1,p2;
real s1,s2;
real t1,t2;
real z1,z2;
real volume1;
real vol_tot1;
real tempo1;
real tavg1;
real rtot;
real val1,val2;
real vol1,vol2;
real moyenne(int id,Domain *domain);
/* global resistance */
real resistance(real a1,real a2)
real resist = 0;
resist = (a1+a2);
return resist;
/* initialization */
DEFINE_ON_DEMAND(reprise)
intensity = 5.5;
r1 = 0.;
r2 = 10.;
/* power sources */
DEFINE_SOURCE(tube_1_source, cell, thread, dS, eqn)
t1 = val1;
rtot = resistance(r1,r2);
intensity = tension/(rtot);
r1 = (vol1*rtotal)*((1+0.0045*(t1-293)));
z1 = (r1*intensity*intensity);
p1 = z1 /vol1;
return p1;
DEFINE_SOURCE(tube_2_source, cell, thread, dS, eqn)
t2 = val2;
r2 = (vol2*rtotal)*((1+0.0045*(t2-293)));
z2 = (r2*intensity*intensity);
p2 = z2 /vol2;
return p2;
/* mean temperature function */
real mean(int id,Domain *domain)
cell_t c;
Thread *t;
t = Lookup_Thread(domain,id);
tavg1 = 0.;
vol_tot1 = 0;
begin_c_loop(c,t)
volume1 = C_VOLUME(c,t);
tempo1 = C_T(c,t);
vol_tot1 += volume1;
tavg1 += tempo1*volume1;
end_c_loop(c,t)
tavg1 /= vol_tot1;
return tavg1;
/* volume function */
real volume(int id,Domain *domain)
cell_t c;
Thread *t;
vol_tot1 = 0;
begin_c_loop(c,t)
end_c_loop(c,t)
return vol_tot1;
/* display */
DEFINE_ADJUST(puissance,domain)
val1 = mean(10095,domain);
val2 = mean(10094,domain);
vol1 = volume(10095,domain);
vol2 = volume(10094,domain);
printf(" temperature1 :%g\n" , val1);
printf(" temperature2 :%g\n" , val2);
printf("power 1 :%g\n" , z1);
printf("power 2 :%g\n" , z2);
printf("tube1 resistance:%g\n" , r1);
printf("tube2 resistance:%g\n" , r2);
fout = fopen("case.txt","a+");
fprintf(fout,"%g %g \n", intensity, rtot);
fclose(fout);
printf("intensity : %g\n" , intensity);
lapin_tout_fou is offline   Reply With Quote
Old   September 13, 2011, 09:23
Thomas
Can anyone help me???
Old   September 22, 2011, 04:51
john
johnwinter is on a distinguished road
Hi Thomas you have to add #if !RP_HOST and #endif at appropriate places. Dealing with print statement bit tricky. For example i modified your code below.
#if !RP_HOST
t1 = val1;
p1 = z1 /vol1;
return p1;
#endif
#if RP_HOST
return 0.0;
#endif
Follow something similar for the rest
Good luck
John
johnwinter is offline   Reply With Quote
Parallel UDF problem Lindsay FLUENT 4 June 20, 2016 10:37
UDF parallel Lucy Fluent UDF and Scheme Programming 3 May 28, 2013 14:14
Help with Define on Demand UDF in Parallel Mahesh FLUENT 2 August 7, 2007 06:34
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 14:53
UDF in parallel version. yobee FLUENT 0 August 17, 2004 05:12
