Syntax errors with Thread Types and Wall Heat Transfer calculation
Old   August 22, 2011, 05:55
Default Syntax errors with Thread Types and Wall Heat Transfer calculation
Jesus Contreras Espada
jcespada is on a distinguished road
I am trying to let Fluent calculate the temperature of a wall that gives a certain heat flux at the end of the calculation. First i run some iterations with a constant temperature at the wall and then I compile (interpreted) the udf and assign it to the wall temperature.
The code looks like this:
#include"udf.h"
DEFINE_PROFILE(wall_temp,t,i)
face_t f;
Thread *f_thread;
Domain *domain = Get_Domain(1);
real x[ND_ND];
real end_heat = 52.939E+06; /* goal heat transfer from the gas to the wall */
real alpha = 1.2; /* correction factor for the wall temperature */
real curr_heat = 0.0; /* current heat transfer from the flow to the wall */
real temper = 300.0; /* face temperature */
thread_loop_f(f_thread, domain)
if(THREAD_TYPE(f_thread) == THREAD_F_WALL)
begin_f_loop(f,f_thread)
curr_heat += abs(BOUNDARY_HEAT_FLUX(f,f_thread));
end_f_loop(f,f_thread)
begin_f_loop(f,t)
temper = F_T(f,t);
F_PROFILE(f,t,i) = temper * alpha;
end_f_loop(f,t)
if (temper >= 1000) temper = 1000; /* temperature is clipped 200K =< T =< 1000 */
if (temper <=200) temper = 200;
The line "if(THREAD_TYPE(f_thread) == THREAD_F_WALL)" does not work. I thought it should be quite easy to verify if a thread is a wall, but I always get the error message "structure reference not implemented". Maybe it has something to do with the installation or the version. I use Fluent 13.0.0.
The macro BOUNDARY_HEAT_FLUX(f,f_thread); gives after 1 iteration "access violation" as output and I have to restart FLUENT.
Finally abs() doesn't work either, since there is no math.h file in the src directory. Any idea how to overcome this?
I would be very thankful, if someone could help.
Thanks in advance and best regards.
J.
jcespada is offline   Reply With Quote
Old   August 22, 2011, 06:24
Default Correction
Sorry, the calculation of the correction factor is missing in the code.
There is a line looking like this between the two big loops:
alpha = curr_heat / end_heat;
Old   March 16, 2012, 03:23
cdf_user is on a distinguished road
what does this statement mean?
cdf_user is offline   Reply With Quote
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 06:47
heat transfer fluid-wall marco FLUENT 7 November 20, 2005 12:34
Pipe wall temperature Fred Uckfield Main CFD Forum 25 May 22, 2000 15:37
