uds flux - drift velocity - udf
Old   August 11, 2011, 05:51
Post uds flux - drift velocity - udf
john
johnwinter is on a distinguished road
Hi All,
I am calculation ion density using UDS udf, i have a flux term in transport equation as (u+mu.E). My udf is given below. I could see nothing wrong with my udf but ion density is rising gradually beyond input value with every iteration due to this term
DEFINE_UDS_FLUX(ion_flux,f,t,i)
#if !RP_HOST
double NV_VEC(A), NV_VEC(E_vec), F_Evec[ND_ND] = {0.}, E_flux = 0.;
cell_t c0, c1 = -1;
Thread *t0, *t1 = NULL;
c0 = F_C0(f,t);
t0 = F_C0_THREAD(f,t);
F_AREA(A,f,t);
if (BOUNDARY_FACE_THREAD_P(t))
E_flux = 0.0;
else
c1 = F_C1(f,t);
t1 = F_C1_THREAD(f,t);
NV_DS(E_vec, =, E_X(c0,t0), E_Y(c0,t0), E_Z(c0,t0), *, ionmob);
NV_DS(E_vec, +=, E_X(c1,t1), E_Y(c1,t1), E_Z(c1,t1), *, ionmob);
E_flux = NV_DOT(E_vec,A)/2.0;
if (i==0)
return (F_FLUX(f,t)/rho+E_flux);
else return (0.);
#endif
#if RP_HOST
return 0.0;
#endif
After 3 iterations i could see that the iondensity value at the node near electorde is rising beyond my input value.
Any suggestion are welcome.
PS: I am stroing E_X, E_Y and E_Z values using memory option.
Thanks
John
johnwinter is offline   Reply With Quote
Old   August 12, 2011, 06:29
john
i need results badly. please somebody help!
Old   February 9, 2017, 11:26
beastieboys6 is on a distinguished road
Hi, John,
I'm facing exactly the same problem when using similar UDF.
I was wondering if you had solved problem. If you had, could you share the solution? Thanks.
Or if there is anyone knowing the soluation? Any suggestion would be highly appreciated.
beastieboys6 is offline   Reply With Quote
Old   November 25, 2017, 05:07
Default SS..Any update on ion Density UDF
Tamil Nadu
sivajiseepana is on a distinguished road
HI do you got any progress on above, kindly post your reply
sivajiseepana is offline   Reply With Quote
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 07:25
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
