Access dimensions of model geometry
Old   July 26, 2011, 23:21
Question Access dimensions of model geometry
N/A
cp_jef is on a distinguished road
Hi Fluent Gurus,
Is there a way to access (call) dimensions of your geometry, eg. radius of an inlet section, from within the udf? I have searched the entire UDF manual and found nothing.
Thanks in advance.
Regards,
John
cp_jef is offline   Reply With Quote
Old   July 31, 2011, 22:44
gearboy is on a distinguished road
Originally Posted by cp_jef View Post
Hi Fluent Gurus,
Thanks in advance.
Regards,
John
No direct macro to return inlet radius, but you can loop all the node on inlet and calculate the maximum distance between two nodes. This is just the inlet width.
gearboy is offline   Reply With Quote
Old   August 1, 2011, 02:11
Thumbs up Thanks...
N/A
Hi Ji,
Thanks for the reply. I went ahead and calculated the radius from the area by adding up the face areas within the inlet face thread (I was performing an area-weighted average of pressure and velocity at the inlet). I initially thought of your idea, but my code is already bogged down with multiple loops and I didn't want to slow it down any further with additional loop and condition statements. Thanks for you input thought, I appreciate it.
Cheers,
John
fluent, udf
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Fluent: changing dimensions of a geometry genetaed Madhukar Rapaka FLUENT 3 October 12, 2005 12:40
how to model geometry of plume from chimney in 3D dave FLUENT 1 July 19, 2005 17:34
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
