Get position of a moving wall every time step in UDF
Old   July 20, 2011, 06:48
Default Get position of a moving wall every time step in UDF
schemer is on a distinguished road
Hey everyone,
I defined a DEFINE_ADJUST function, where I patch water every time step to a wall. This should simulate raindrops on a windshield. This works up to this point. The problem is, that there is also a wiper that moves left and right along the windshield wall. I want to patch the water always just on the right hand side of this wiper. Now, my question is, if there is a possibility to get the position of the wiper. I already tried to do it with
begin_f_loop(face, tf) /* get position of blade */
F_CENTROID(xf, face, tf);
xblade = xf[0];
end_f_loop(face, tf) ,
but this doesn't seem to work in the DEFINE_ADJUST environment.
Maybe there is a special command, I havn't found in the manual, yet?
I use the following settings: 2D, Dynamic Mesh, VOF, Transient
Thanks a lot for your help!
schemer is offline   Reply With Quote
Old   August 9, 2011, 11:57
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Did you use a different subdomain and corresponding thread pointer for the thread "tf" here. I think you will have to use the subdomain for the wiper and then define the thread for that.
pranab_jha is offline   Reply With Quote
Old   August 10, 2011, 03:41
Now, I solved the problem by defining a function in the UDf that gets the F_CENTROID of the blade. This is the function that works finally:
void Get_Thread_Face_Centroids(Domain *domain, int id)
  real FC[2];
  face_t f;
  Thread *t = Lookup_Thread(domain, id);
  begin_f_loop(f,t)
     F_CENTROID(FC,f,t);
     xblade=FC[0];
  end_f_loop(f,t)
Thanks for your help anyway!
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Time step in transient simulation shib FLUENT 0 June 17, 2010 14:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 12:33
