June 8, 2011, 05:23 |
parallelizing the udf for multi core machine
Aamer Shahzad
Rep Power: 16 |
Hello all.....
i have written a serial udf to give azimuth rotation to the wing. The code is as follows. #include "udf.h" static real psi_dot = 0.0; /* rotational velocity */ DEFINE_CG_MOTION(Re_34000ar6, dt, vel, omega, time, dtime) { Thread *t; face_t f; real gyration = 0.1927; /*second moment of area*/ real c = 0.101; /* wing chord in meters */ real t_A = 0.0269; /* t_A is time required to accelerate wing from rest */ real pi = 3.14159; real a; real U = 5; /* constant velocity */ real constant = 0.35; real psi_dot; /* rotational velocity */ real psi; /* azimuth angle */ real psi_not_dot = 25.947; /* constant rotational velocity*/ /*reset velocities*/ NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P ()) return; if (time <= t_A) { psi_dot = (12.97)* (1 - cos((pi*time)/(t_A))); psi = (12.97)* (time - ((t_A/pi)*sin((pi*time)/(t_A)))); } else { psi_dot = psi_not_dot; psi = (psi_not_dot*time)-constant; } a= -(psi_dot); Message("time:%f psi:%f psi_dot:%f\n",time,psi,a); omega[0]= 0; omega[1]= a; omega[2]= 0; I have a quad core processor machine. when i try to run my case file by giving "fluent -t4", it gives me error " the current working directory c:\users\aamer is not shared, this may cause file open issues accross network" " primitive error at NOde 0: open_udf_library:the system cannot find the file specified." similar error is displayed for other nodes. the same file works perfectly fine in parallel when there is no udf, hooked to it. so i think i have to parallelize the udf for my multi processor machine...... can anybody help me parallelize this code. any suggestions or comments??????? |
August 22, 2013, 03:03 |
fateme
hello aamer
I have the same problem with parallelizing of an udf!! could you solve it? please tell me what should i do for solving it. thanks in advance. |
August 22, 2013, 05:48 |
Paritosh Vasava
Rep Power: 22 |
You have to use the macros #if RP_HOST and #if RP_NODE.
Reading this (http://aerojet.engr.ucdavis.edu/flue...df/node206.htm) would help. |
Problem with UDF on a Linux machine (Red Hat) | Iaroslav | Fluent UDF and Scheme Programming | 6 | March 7, 2017 13:15 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Help Parallelizing UDF | AndresC | FLUENT | 0 | February 25, 2010 15:50 |
Distributed Parallel on dual core remote machine | Justin | CFX | 1 | February 3, 2008 17:23 |
