May 25, 2011, 05:53 |
UDF Done
jason
Rep Power: 15 |
I am simulating a wing using fluent and want to output all the aerodynamic forces into a txt or dat file, does anyone know which udf command shoud i use. I know command "message " only shows the forces on the windows, so anyone knows please give me a hand, many thanks
May 26, 2011, 13:56 |
jason
Rep Power: 15 |
Ok i made this script to integrate the forces however it only works as a interpreted UDF and not a compiled UDF. Any ideas?
/************************************************** ****************** ************************************************** *******************/ #include "udf.h" #define airfoil_tid 15 /* Zone ID of airfoil */ #define domain_zone 1 float P_i; float A_i; float U_i; float V_i; float W_i; float Fpx; float Fpy; float A[3]; Domain *domain; face_t f; /* airfoil surface*/ Thread *t;/* wing thread*/ DEFINE_ADJUST(forces,domain) { domain = Get_Domain(domain_zone); t = Lookup_Thread(domain, airfoil_tid); Fpx=0; Fpy=0; begin_f_loop(f,t) { F_AREA(A,f,t); P_i = F_P(f,t); Fpx += P_i*A[0]; Fpy += P_i*A[1]; } end_f_loop(f,t) printf("forces are: %f\n,%f\n", Fpx,Fpy); } |
May 31, 2011, 06:27 |
Dragos
Rep Power: 20 |
The normal way is to include <stdio.h> when you want to use printf. However, try to use Message, instead of printf, it takes exactly the same arguments.
You have to be aware, though, that your udf will not work correctly in parallel (due to the face summation). |
May 31, 2011, 08:52 |
jason
Rep Power: 15 |
thanks dmoroian, do you have any ideals about the commands for parallel? many thanks
May 31, 2011, 09:09 |
short example
Dragos
Rep Power: 20 |
#include "udf.h" #include "prf.h" #define airfoil_tid 15 /* Zone ID of airfoil */ #define domain_zone 1 float P_i; float A_i; float U_i; float V_i; float W_i; float Fpx; float Fpy; float A[3]; Domain *domain; face_t f; /* airfoil surface*/ Thread *t;/* wing thread*/ DEFINE_ADJUST(forces,domain) { #if !RP_HOST domain = Get_Domain(domain_zone); if(NULL == (t = Lookup_Thread(domain, airfoil_tid))) Error("Something is wrong with the thread:0x%x\n",t); Fpx=0; Fpy=0; begin_f_loop(f,t) { F_AREA(A,f,t); P_i = F_P(f,t); Fpx += P_i*A[0]; Fpy += P_i*A[1]; } end_f_loop(f,t) Fpx = PRF_GRSUM1(Fpx); Fpy = PRF_GRSUM1(Fpy); Message0("forces are: %f\n,%f\n", Fpx,Fpy); } |
June 2, 2011, 09:46 |
jason
Rep Power: 15 |
Hi dmoroian, thanks for the help, I was trying to get the shear stress along the airfoil, however, got some problems when i check the values: code shows below:
/************************************************** ****************** UDF for integrating pressure forces and displaying it in the console ************************************************** *******************/ #include "udf.h" #include "metric.h" #include "mem.h" #define airfoil_tid 13 /* Zone ID of airfoil */ #define domain_zone 1 float DUDX,DUDX1; float pressure; float DPDX1; int counter; int nface; int a; int b; int zone_ID; Domain *domain; face_t f; /* airfoil surface*/ cell_t c; cell_t c0; Thread *t; Thread *t0; Thread *t1; DEFINE_ADJUST(forces,domain) { //if (!Data_Valid_P()) return; domain = Get_Domain(domain_zone); t = Lookup_Thread(domain, airfoil_tid); //zone_ID = THREAD_ID(t); /*out put the airfoil thread number*/ //Message("zone_ID: %d\n",zone_ID); //counter = 0; //if(b = BOUNDARY_FACE_THREAD_P(t)); //{Message("boundary: %d\n", b); //} begin_f_loop(f,t) { t0 = F_C0_THREAD(f,t); c0 = F_C0(f,t); nface = C_NFACES(c0,t0); DUDX = C_DUDX(c0,t0);/* seems problems come from here, which not match to the fluent post-process values, see the values at the bottom*/ pressure = C_P(c0,t0);/*also the pressure force is not right as well*/ a = FLUID_THREAD_P(t0); /* check whether t0 is a thread in the domain*/ Message("DUDX: %e,%d,%d,%e\n",DUDX,nface,a,pressure); } end_f_loop(f,t) begin_c_loop(c,t) { //if (BOUNDARY_FACE_THREAD_P(t)) // { DPDX1 = C_P_G(c,t)[0]; //t1 = C_FACE_THREAD(c,t,0); // c = C_FACE(c,t,0); //Message("DPDX = %e\n", DPDX1); // } } end_c_loop(c,t) } ******************************************** values from the codes: this colume is pressure force at wall DUDX: 3.746866e+000,4,1,-1.851858e+001 DUDX: -1.253381e+000,4,1,-2.228758e+001 DUDX: -4.220629e+000,4,1,-1.864905e+001 DUDX: -2.343874e+000,4,1,1.658862e+001 DUDX: -9.178568e+001,4,1,1.796235e+001 DUDX: -2.398940e+000,4,1,1.648010e+001 DUDX: -5.881291e+000,4,1,-2.434795e+001 DUDX: -5.239357e+000,4,1,-2.471040e+001 DUDX: -5.963025e+000,4,1,-2.434571e+001 DUDX: 4.096624e+000,4,1,-1.958149e+001 DUDX: -1.208462e+000,4,1,-2.364586e+001 DUDX: -4.264113e+000,4,1,-1.990714e+001 *********************************************** forces from the fluent write file, from plots of du/dx--x and pressure--x pressure du/dx -20.3986 1.24743 -20.4641 -2.73684 -21.4992 -5.42141 -24.5353 -5.63565 -24.534 -5.66827 -22.1281 -5.43965 -21.7746 -2.73628 -21.6116 1.44466 -1.54782 0.625361 17.2248 -47.0923 17.2791 -47.0647 -0.960895 0.08465 **************************************** below is the case file: element_test.zip |
June 3, 2011, 02:59 |
Dragos
Rep Power: 20 |
I'm sorry, but I don't really understand your problem. It seems different than the first one above.
August 31, 2011, 01:57 |
Hii friendss.. i have worked out with 2d udf for parabolic velocity inlet.
please help me how this code will change with 3d. i wanna know how will be the equation considering 3rd dimmension. as in 2d we have V(x)=Vmax- y^2/(disatnce from centre in y direction )^2 * Vmax. please help me. also give suggestion how to work out on sinusoidal inlet udf. thanks in advance |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
