May 23, 2011, 05:44 |
Parallel DPM Udf problem
Johney Grey
Rep Power: 15 |
Hi, all! I wrote a DPM UDF for fluent 6.3.26. But I don't know how to edit it to parallel UDF(1CPU 8cores ). Can anyone help me, plz?
By the way, could this udf run on Liunx system? #include "udf.h" #include "dpm.h" #include "math.h" #include "time.h" #include "stdio.h" static int n=0; double integral(double s) // to generate a parabolic particle distribution { double a=0.0,b=5.0,mid=2.5,y=-0.004*mid*mid*mid+0.3*mid; for(;fabs(s-y)>1e-6; ) { if(s>y) { a=mid; mid=(mid+b)/2.0; } else { b=mid; mid=(a+mid)/2.0; } y=-0.004*mid*mid*mid+0.3*mid; } return mid; } DEFINE_DPM_INJECTION_INIT(init_particles,I) { Particle *p; FILE *fp; real xm[ND_ND]; double R=0.0, x=0.0, y=0.0, an=0.0,k=0.0; if(n==0)srand((unsigned)time( NULL )); k=rand()/(double)(RAND_MAX); R=integral(k); an=rand()/(double)(RAND_MAX)*2*3.1415926; x=R*sin(an)/200.0; y=R*cos(an)/200.0; Message ("\n n=%d, k=%f\n",n, k); n++; p=I->p_init; P_POS(p)[0]=x; P_POS(p)[1]=y; P_POS(p)[2]=0.0; Message ("particle position x=%f, y=%f\n", P_POS(p)[0],P_POS(p)[1]); xm[0]=P_POS(p)[0]; xm[1]=P_POS(p)[1]; xm[2]=P_POS(p)[2]; P_DIAM(p)=5e-6; P_RHO(p)=1000; P_MASS(p)=P_RHO(p)*M_PI*pow(P_DIAM(p),3.0)/6.0; P_FLOW_RATE(p)=P_MASS(p)/0.06; fp=fopen("e:\\test\\pa.txt","at"); fprintf(fp,"%f %f %f\n",R,xm[0],xm[1]); fclose(fp); } |
June 10, 2011, 05:12 |
john
Rep Power: 16 |
for parallel code you should keep
#if !RP_HOST #endif and #if ! RP_NODE #endif has to be kept at appropriate places in the code. See UDF manual for more details |
June 10, 2011, 09:26 |
Johney Grey
Rep Power: 15 |
Thanks for your reply. But I just don't know where to put them. The manual only has one page mentioned about the paralleliztion of DPM model. And it mainly talks about message output.
June 11, 2011, 01:43 |
john
Rep Power: 16 |
HI i am not an expert, based on my knowledge i have corrected your code below
#include "udf.h" #include "dpm.h" #include "math.h" #include "time.h" #include "stdio.h" static int n=0; double integral(double s) // to generate a parabolic particle distribution { #if !RP_HOST double a=0.0,b=5.0,mid=2.5,y=-0.004*mid*mid*mid+0.3*mid; for(;fabs(s-y)>1e-6; ) { if(s>y) { a=mid; mid=(mid+b)/2.0; } else { b=mid; mid=(a+mid)/2.0; } y=-0.004*mid*mid*mid+0.3*mid; } return mid; #end if } DEFINE_DPM_INJECTION_INIT(init_particles,I) { #if !RP_HOST Particle *p; FILE *fp; real xm[ND_ND]; double R=0.0, x=0.0, y=0.0, an=0.0,k=0.0; if(n==0)srand((unsigned)time( NULL )); k=rand()/(double)(RAND_MAX); R=integral(k); an=rand()/(double)(RAND_MAX)*2*3.1415926; x=R*sin(an)/200.0; y=R*cos(an)/200.0; // Message ("\n n=%d, k=%f\n",n, k); n++; p=I->p_init; P_POS(p)[0]=x; P_POS(p)[1]=y; P_POS(p)[2]=0.0; //Message ("particle position x=%f, y=%f\n", P_POS(p)[0],P_POS(p)[1]); xm[0]=P_POS(p)[0]; xm[1]=P_POS(p)[1]; xm[2]=P_POS(p)[2]; P_DIAM(p)=5e-6; P_RHO(p)=1000; P_MASS(p)=P_RHO(p)*M_PI*pow(P_DIAM(p),3.0)/6.0; P_FLOW_RATE(p)=P_MASS(p)/0.06; #endif node_to_host_real_3(R, xm[0],xm[1]); #if !RP_NODE fp=fopen("e:\\test\\pa.txt","at"); fprintf(fp,"%f %f %f\n",R,xm[0],xm[1]); fclose(fp); #endif } you may need to change some more look at carefully and change. all the best |
June 11, 2011, 11:03 |
#5 | |
Johney Grey
Rep Power: 15 |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 08:24 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
A UDF Problem in Parallel Mode | Jun | FLUENT | 1 | October 26, 2011 13:49 |
problem loading UDF in parallel fluent | Tim | FLUENT | 12 | July 12, 2008 13:59 |
DPM - UDF for fluctuating bubble size | Jaroslav Kotara | FLUENT | 1 | April 19, 2006 10:02 |
