john
Rep Power: 16 ![]() |
Hi All,
I am writing a simple udf to solve electric field. I have two UDS transport equations in the problem. when i run my udf in fluent 6.3.26 i am getting error in this particular source function. it is saying "FLOATING POINT ERROR: Invaled number". Could anynody please tell me where i went wrong. E_vec is defined as C_UDSI_G(c,t,0) DEFINE_SOURCE(ion_source,c,t,dS,eqn) { face_t f; Thread *tf; int n; double NV_VEC(E_vec), NV_VEC(A); double source; source=0.0; c_face_loop(c,t,n) { f=C_FACE(c,t,n); tf=C_FACE_THREAD(c,t,n); F_AREA(A,f,tf); NV_D(E_vec,=, E_X(c,t), E_Y(c,t), E_Z(c,t)); if(THREAD_TYPE(tf)==THREAD_F_WALL) { source=NV_DOT(E_vec,A)*ionmob/NV_MAG(A); } } if( C_UDSI(c,t,0) <0) source=0.0; else source -= source; dS[eqn]=source; source*=C_UDSI(c,t,0); return source; } |
john
I am already saving the gradient data in user memory using C_UDMI. But still it has problem |
from UDF manual:
you can prevent the solver from freeing up memory by issuing the text command solve/set/expert and then answering yes to the question Keep temporary solver memory from being freed?. Note that when you do this, all of the gradient data is retained, but the calculation requires more memory to run. |
john
The UDF is working as it is when i hook the source term after one iteration.
john
Hi All,
When i run the simulation with UDS for nagative ions, i am getting negative values in the contour plots. I checked source and flux term for each cell they are all positive values. How come i am getting negative values in the domain? I guess i am getting nagative values at the nodes?. how to recify it. Please help John |
Source Term on Scalar Transport Equation | alessio.nz | OpenFOAM Programming & Development | 9 | January 31, 2011 08:56 |
gradient source term UDF | ak6g08 | Fluent UDF and Scheme Programming | 0 | July 9, 2009 07:37 |
Stokes equation with source term | dak81 | OpenFOAM Running, Solving & CFD | 0 | March 12, 2008 09:41 |
Source term in the mass balance equation | Mehdi BEN HAJ | Phoenics | 0 | January 31, 2007 17:30 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
