writing udf
Old   April 23, 2011, 02:51
Default writing udf
massoumeh
rostamimass is on a distinguished road
dear all
i am writing a source-udf. in that formula there is some derivative terms depending on time. i dont know how should i write them or which macro should use, for example there is d/dt(du/dy+dv/dx) in formula for source term. thanks
rostamimass is offline   Reply With Quote
Old   April 23, 2011, 14:13
Amir's Avatar
Amir
Amir is on a distinguished road
Hi masumeh,
you know that this kind of UDF executes every iteration so, it's enough that you use global parameter and put the desired variable in, then in new time step use the parameter value for last time step and then put new one to it. (note that you should renew the global parameter every time step not every iteration)
Amir is offline   Reply With Quote
Writing UDF (DEFINE_PROFIL) for two surfaces Geisel Fluent UDF and Scheme Programming 5 June 21, 2010 09:38
Seek help in writing UDF Jack Martinez FLUENT 9 June 14, 2007 11:24
New to writing UDF Sandilya FLUENT 0 May 31, 2007 13:03
Writing UDF for Robbins Bounday Condition KKLAU FLUENT 1 April 7, 2004 00:58
Macros for writing UDF for porosity umesh FLUENT 1 June 13, 2003 05:20
