gravity direction
Old   March 30, 2011, 12:48
Default gravity direction
Pietro Romanazzi
metello is on a distinguished road
does anybody know if it's possible to change the direction of the gravity acceleration with a time dependent UDF?
Thanks!!
metello is offline   Reply With Quote
Old   March 30, 2011, 17:10
Amir's Avatar
Amir
Amir is on a distinguished road
I've done it before with a proper journal file. I don't think that it can be done with UDF!
Amir is offline   Reply With Quote
Old   March 30, 2011, 17:24
Pietro Romanazzi
Thanky you for the reply,
I was thinking to use a journal file as well, but I tried write this UDF. Unfortunately it's wrong because "gravity" isn't the variable right name. Do you know which could be the proper one?
#include "udf.h"
#define PI 3.14159
DEFINE_ADJUST(gravity_change,d)
cell_t c;
Thread *t;
real gr[ND_ND];
real time=RP_Get_Real("flow-time");
if (time<0.25)
gr[0]=9.81*sin(PItime*4/0.25);
gr[1]=9.81*cos(PI/180*time*4/0.25);
gravity[0]=RP_Set_Real(gr[0]);
gravity[1]=RP_Set_Real(gr[1]);
Old   March 31, 2011, 04:18
Amir's Avatar
Amir
if you want to write a UDF, I have a suggestion. you can implicitly involve a gravitational effect by importing a source term in momentum equations, here it doesn't need to activate gravity effect in fluent instead write 2 UDFs for x and y momentum equations via DEFINE_SOURCE macro.
Old   March 31, 2011, 08:56
Pietro Romanazzi
Great idea!
Could you be so kind to give me an example?
Old   March 31, 2011, 10:12
Amir's Avatar
Amir
Originally Posted by metello View Post
Great idea!
of course,
your x and y momentum sources change with time. e.g. for rotating gravity it would be:
s_x=rho*g*cos(wt)
s_y=rho*g*sin(wt)
to implement a DEFINE_SOURCE UDF you can refer to UDF manual. I think it's clear.
Old   March 31, 2011, 12:02
Pietro Romanazzi
I really don't know how to thank you!
But I have another question, I hope it will be the last!
Since my problem is multiphase, is it possible to read Rho or is it suppose to be a constant?
Old   March 31, 2011, 12:09
Amir's Avatar
Amir
I think, if you use C_R(c,t) as rho, FLUENT automatically account for that.
Old   April 1, 2011, 11:10
Pietro Romanazzi
It works!
Thank you for all these aids Amir!
MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed bengt OpenFOAM Running, Solving & CFD 2 May 28, 2010 15:45
how to consider gravity in CFX shrimp CFX 4 September 8, 2008 21:41
changing gravity vector direction using UDF Nico FLUENT 0 September 7, 2006 13:00
Gravity component and inlet velocity Vidya FLUENT 8 July 31, 2006 09:28
Help: gravity in CFX Dejun Jing CFX 2 July 22, 2002 09:58
