(ask) how to create UDF for inlet velocity profile
Like Tree21Likes
Old   June 8, 2018, 12:17
pakk will become famous soon enough
I use TextPad or Vim.
cfd_worker99 likes this.
pakk is offline   Reply With Quote
Old   August 8, 2019, 05:40
Default negatif values
  #82
Elvire Katramiz
elvirekatramiz is on a distinguished road
Hello!
I have a question concerning the velocity profile.
I did the UDF function and compiled it in ANSYS fluent, however I need to assign it to a BC of inlet velocity? if so, it only gives positive values of the velocity... how can the velocity change from + to - on a boundary and thus change the direction of the velocity vectors?
should I change the type of boundary conditions?
Thank You !!
elvirekatramiz is offline   Reply With Quote
Old   August 8, 2019, 08:49
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
if we speak about inlet boundary condition ->
positive velocity means flow inside domain
negative velocity means flow onside domain through inlet
best regards
AlexanderZ is offline   Reply With Quote
Old   May 16, 2022, 14:04
Default How can set velocity component in UDF
  #84
ali
alireza_T is on a distinguished road
hello everybody, I need a UDF for the set velocity component.
for example. I want to set y velocity or anything else. so how can write it?
for example on the fluent, you can set ...
how can write it on the UDF, now?
alireza_T is offline   Reply With Quote
UDF problems - velocity profile Oli Fluent UDF and Scheme Programming 6 October 24, 2016 11:38
How to create non-uniform velocity profile in FLUENT? pankaj FLUENT 7 October 24, 2016 05:52
udf for velocity profile in a geometry having two inlets shubham208011 Fluent UDF and Scheme Programming 0 April 6, 2009 16:13
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
UDF velocity profile at nodes Emad FLUENT 2 January 29, 2009 07:35
