March 5, 2011, 15:36 |
Cg_motion udf
Rep Power: 16 |
I've to analyze a cylinder (2d) constrained with a spring, so the differential equation is S''+w^2 S= F(t) with S= displacement w=sqrt(K/m) and F(t) is the pressure force (time function). How can i solve this problem? The UDF manual describe F=m*dv/dt and use Euler's formula, so V(t)=(F/m)*Dt+V(t-Dt) how can i write the correct scheme for my problem? Thanks |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
