UDF for body force in DPM
Like Tree2Likes
Old   August 23, 2011, 10:12
Amir's Avatar
Amir
Amir is on a distinguished road
Originally Posted by elah599 View Post
Dear Amir
I read the help of fluent for UDS and unfortunately I didn't get what should I do. do I have to solve the flow for multiphase flow or single phase flow? is just enough to consider coefficient of diffusion in material tab? if you have a simple case file, it would be great if you can send me that until I know what should I do. because I didn't find a proper tutorial for this concept.
thanks for your support
Dear Iman,
Generally, you can add number of extra scalar transport to current solver; e.g.: \partial(\rho C)/\partial t+\nabla.(\rho UC)=\nabla.(D\nabla C) + sources
They are added to another equations which are provided; something like energy equation, so it's not need to use multiphase models, it's applicable to single phase as well. Just note dimension of diffusion coefficient which you have to set in kg/(m.s); i.e, it's \rho D not D. Other setting is like setting of energy equation, you would need B.C and .... The result is particle concentration (C) as it's expected.
Unfortunately, I don't have small case which I can upload now; nevertheless, if these tips couldn't help you, inform me and I'll prepare one.
Bests,
Amir
Amir is offline   Reply With Quote
Old   January 26, 2012, 16:41
mamad
m.salemi is on a distinguished road
Originally Posted by Amir View Post
Dear Iman,
Bests,
Hi Amir,
I'm interested in scalar transport for solving such problem,can you help me about this or send a case about this for me???
m.salemi is offline   Reply With Quote
Old   January 27, 2012, 04:35
Amir's Avatar
Amir
Do not hesitate to ask if it's not clear. Just preparing a case is not helpful I think, because it's really case dependent.
Bests,
Amir
Old   January 28, 2012, 15:34
mamad
Bests,
Hi Amir,
thanks a lot,
i want to modeling effect of nanoparticles in water,can you help me???
Old   January 28, 2012, 16:50
Amir's Avatar
Amir
Originally Posted by m.salemi View Post
Hi Amir,
thanks a lot,
sure; using Eulerian method seems reasonable for your purpose if it matches with your goal; nevertheless, selecting Lagrangian procedure has few issues specially in nano particles; so the only thing you have to do is to activate a scalar equation, set proper diffusivity and UDS BC; isn't it clear or face a trouble?
Bests,
Amir
Old   January 28, 2012, 17:49
mamad
Bests,
Thanks a lot dear Amir,
but isn`t clear, i don`t know proper diffusivity and BC for this problem, can you explain this???
Old   January 29, 2012, 04:06
Amir's Avatar
Amir
The diffusivity of a substance in another is obtained from kinetic theory and you have to find it from literature (D). This parameter has a dimension of (m2/s) but as I explained the scalar transport equation is:
\partial(\rho C)/\partial t+\nabla.(\rho UC)=\nabla.(\rho D\nabla C) + sources
and you have to set \rho D for FLUENT which has a dimension of (kg/m.s), but note that the \rho is the base fluid density and D is diffusivity of desired substance in that fluid.
About the BCs, you have 3 options to set value or gradient or write a UDF for that; you have to set appropriate BC according to your model; e.g., if you set zero gradient it means that there isn't any penetration of the UDS and if you set zero value it means that there is a sink of that UDS.
Bests,
Amir
Old   January 29, 2012, 11:31
mamad
Bests,
Hi amir
Thanks a lot for your answering...
i have some question about your answer,
should i solve this equation with continuity,momentum and energy equations and coupled with them???if yes, how can i do this work???
and can i use this equation in common model or i should use DPM or other model???
Old   January 29, 2012, 16:10
Amir's Avatar
Amir
No, this equation is solved in decoupled manner with both pressure and density based solvers.
No, you can use this equation with any solver; it just adds additional equations.
Bests,
Amir
Old   June 15, 2012, 21:51
Default loop over particles
  #50
Shawn Fotovati
sfotovati is on a distinguished road
Hi guys,
I need to find electromagnetic force induced by other particles over the tracked particle. Can I loop over particles while I am using DEFINE_DPM_BODY_FORCE ??!
I tried "loop(p,I->p)", but it did not work. I also used "begin_particle_cell_loop" macro, it did not work either.
Please let me know if you can help me.
Thanks
Shahryar.
sfotovati is offline   Reply With Quote
Old   June 17, 2012, 05:50
Amir's Avatar
Amir
Originally Posted by sfotovati View Post
Hi guys,
Thanks
Shahryar.
Dear Shahryar,
You cannot make a loop over particles in this macro because the particles are tracked sequentially.
Bests,
Amir
Old   June 17, 2012, 06:51
Shawn Fotovati
Thanks for the reply Amir,
What about the macro "begin_particle_cell_loop"?
I tried that one. I was able to compile it but it gives me access_violation error as I run the DPM. Do you have any idea how to use this macro in define DPM body force?
Thanks.
Old   June 17, 2012, 08:38
Amir's Avatar
Amir
Thanks.
There isn't any conceptual difference. You cannot loop over particles according to their index or location because of sequential algorithm. You need to change your algorithm; maybe select another macro or use temporary memories to store particle effects ......
Bests,
Amir
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 16:33
UDF force on a face enry Fluent UDF and Scheme Programming 10 March 23, 2011 11:48
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 18:45
DPM drag force UDF hedonists FLUENT 0 March 12, 2003 22:10
