Boiling over hot cylinder surface
Old   February 16, 2011, 14:54
Default Boiling over hot cylinder surface
Hamdy
hamdy is on a distinguished road
I am working on round water jet that impinges hot surface at 400 deg C. The problem including boiling and wetting front propagation for water. I have the following problems:
  1. The number of phases are 3: air, water and water vapor, or 2: water and water vapor only.
  2. is it better to use vof or eulerian model
  3. what is the recommended UDF in C format.
  4. How to activate vof model properly in this case
  5. Is there a need to set function hooks
  6. the case is interpreted or compiled
  7. is there any tutorial that may help
Awaiting for your kind help and support. Thanks...
hamdy is offline   Reply With Quote
Old   June 11, 2011, 02:29
majid sattarcheh
majidsa6 is on a distinguished road
u can use ansys fluent release 13 for modeling of boiling.
majidsa6 is offline   Reply With Quote
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface James Date CFX 3 August 10, 2012 05:47
free surface flow past cylinder vineet FLUENT 1 February 22, 2011 00:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
Patran Volume Meshing Deb CFX 19 April 17, 2003 11:56
