Fluent does not always compile UDF properly
Old   February 10, 2011, 05:27
Default Fluent does not always compile UDF properly
Dave Smith
davesmith_01 is on a distinguished road
When I open a UDF with fluent sometimes it works, I have MS Visual 2008, and open fluent using the command prompt, and using win xp 32bit. And at other times if I copy this UDF to another folder and try and open it again to run another case it crashes and displays this message
'Error: Fluent recieved a fatal signal (segmentation violation).
Error Object: ()'
How can I fix this, I don't understand why it works sometimes only, also most of the time I am recieving this error now.
Dave
davesmith_01 is offline   Reply With Quote
Old   February 10, 2011, 08:24
DoHander is on a distinguished road
Try an experience:
1. Use a folder without spaces in the path, for e.g.: C:\myudf
2. Try something different: C:\Me\My Documents\myudf
Notice the space in the second example.
Also, always start Fluent from VS command prompt.
Do
DoHander is offline   Reply With Quote
Old   February 10, 2011, 12:45
Dave Smith
Hi Do
I tried what you said but it didnt work. I even tried to replace every space with a dot, but that didnt work either. Thanks for trying to help
I don't understand the unstability of fluent, this is another mistake I have spotted in two weeks.
Do you know anything else that I could try, also if I use Fluent in
win xp x64 how can a UDF be compiled, will I need to have MS visual x64 and use the command prompt x64 to open fluent x64?
Dave
Old   February 10, 2011, 15:09
Yep, for Fluent 64 bits you will need VS 2008 for 64 bits.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
fluent UDF on linux machine Min-Hua Wang Fluent UDF and Scheme Programming 6 June 29, 2013 09:41
Fluent (ANSYS12) UDF Help, PLEASE! Urgent! ANITIX87 FLUENT 21 April 12, 2011 04:55
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 12:19
Help to Compile UDF chiph FLUENT 2 November 2, 2003 10:14
