Free water jet impinging hot solid surface, including boiling |
January 25, 2011, 12:17 |
Hamdy
Rep Power: 15 |
I am working on round water jet that impinges hot surface at 400 deg C. The problem including boiling and wetting front propagation for water. I have the following problems:
July 3, 2012, 08:53 |
Subhasish Mitra
Rep Power: 17 |
If it's still important to you,
- The problem can be treated in both eulerian (air, water) and lagrangian (air, water droplet and water vapor) approach. - The boiling model available in ansys 13/14 can be used for solid liquid heat transfer. UDF can also be used to model mass transfer phenomena. - Species transport model will be required to account for vapor phase. -turbulence model will also need to be incorporated. Hope it helps,
SM |
August 19, 2012, 06:28 |
Jan
Rep Power: 14 |
Hi Subha,
Im hoping you may be able to help with a similar problem. I need to simulate a water jet into air, i have a simple rectangular domain. I will be using vof. To set up this problem i have specified velocity inlet of 10ms with volume fraction of water as 1. I was hoping this would allow the water to be injected into the domain however this is not correct. Im a little confused how to approch this problem, will i need to create injection of upload a udf to specify the travel of the water. I thought species transport may work but im still having problems with this. I hope you can help, Thanks |
August 19, 2012, 09:24 |
#4 | |
Subhasish Mitra
Rep Power: 17 |
Hi Caney,
Are you using a 3D grid? You can use a "velocity inlet" (a small orifice), "wall with slip" around and a "pressure outlet" as outlet boundary condition. A turbulence model will be required. You can use both eulerian-eulerian method and VOF to simulate the phenomena. If you are interested in jet length and shape, any of these approach will do. In either of these two case, you need to supply the velocity magnitude and water volume fraction = 1.0 at the inlet. You can use DPM spray model to simulate the jet as well if you are interested to know the each droplet's fate. I don't envisage any species transport here if it's a cold jet being sprayed into air. Regards, Quote:
SM |
August 19, 2012, 09:46 |
Jan
Rep Power: 14 |
Hi Subha,
Thanks for the quick response. I am actually trying a 2D to start with. I have an inlet with velocity magnitude of 10m/s and have specified the volume fraction of water as 1. I also have wall with no slip and pressure outlets. I have set phase 1 as air and phase 2 as liquid. Is this correct? When i run the simulation and check the volume fraction of the phases air and water, the air seems to appear at the pressure outlets. and water seems to be in the whole domain. This is confusing me. I guess i have to simulate the water through the velocity inlet which for some reason i am not getting correct. So you have an idea how i can solve this? Thanks again for your help. Regards Sorry forgot to mention i am using vof model with species transport and LES turbulence model. Last edited by canev.civelek; August 19, 2012 at 10:03. |
August 19, 2012, 20:52 |
#6 | |
Subhasish Mitra
Rep Power: 17 |
Hi Caney,
I guess you are assigning the entire inlet boundary as "velocity inlet". This would fill the entire domain with water. Only the orifice at the inlet (few mm) needs to be assigned as velocity inlet and you should get a conical shape jet structure. Rest of the inlet boundary can be assigned as "wall with slip". Assign air as continuous phase and water as dispersed phase. No species transport is required. LES model is fine but you need to use a really dense mesh if you wish to resolve the eddies. Hope it helps. Quote:
SM |
boiling modeling, free water jet, quenching |
Free surface flow settubg boundary conditions and plotting velocity profiles | prashanthreddyh | FLUENT | 2 | October 21, 2015 10:58 |
Boiling of water with hot air | Dr. Flow Squad | CFX | 2 | July 27, 2009 08:37 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 14:43 |
gravitational force for free surface flow | Jongtae Kim | Main CFD Forum | 1 | July 2, 2000 12:57 |
Radial jet with free surface using FIDAP | Dr. Ahmed Hassaneen | Main CFD Forum | 0 | October 28, 1999 14:20 |
