What is : 1.#QNBe+00
Old   January 11, 2011, 20:00
Default What is : 1.#QNBe+00
MASOUD
MASOUD is on a distinguished road
I got the following error under convergence history of a UDS:
1.#QNBe+00
I am wondering why this occurs and how I can fix it
Thanks
MASOUD is offline   Reply With Quote
Old   December 30, 2011, 23:21
Qiulan Zeng
qiulan is on a distinguished road
Hi!
I encounterd the same problem. Have you solved it? Could you tell me how to solve it? Thank you very much!
qiulan is offline   Reply With Quote
Old   December 31, 2011, 06:45
duri
duri is on a distinguished road
Some floating point error may be ap is going to zero or sqrt of some negative value. You need to investigate it.
duri is offline   Reply With Quote
Old   January 3, 2012, 07:31
Qiulan Zeng
Than you very much! Could you tell me what you usually investigate in this case? The quality of the mesh or the boundary conditions? Thank you again!
Old   January 3, 2012, 14:58
duri
Check boundary condition for zero or negative values and also UDF (if any)
Old   January 8, 2012, 08:49
Qiulan Zeng
Ok, thank you very much!
Old   January 8, 2012, 08:54
Qiulan Zeng
By the way, I have done successfully for two phases, but failed when the third phase which is anologious to one of the previous phases was added. I don't know why since their boundary conditions and UDF are almost the same except for little change of the value. Any suggestion will be appreciated. Thank you very much!
