temperature at a point
Like Tree1Likes
Old   September 16, 2015, 01:50
Surya
hariswch2 is on a distinguished road
Originally Posted by ghost82 View Post
Try to declare nt as real, not integer, maybe the division returns 0 if nt is defined as int.
can you also change name p to something else?maybe 'p' is reserved?
Below shown was modified program as suggested but still heater is not cutting off...it is still on position only
#include "udf.h"
real thermosensor=300.0;
/* Obtain the mean temperature at the location of thermocouple */
/* Thermocouple located at coordinates (x,y,z) = (0.115,0.135,0.25) */
DEFINE_EXECUTE_AT_END(tsensor) /* exectued at the end of time step in trasient and iteration in steadddy state*/
real thermosensor_coordinate[ND_ND];
real thermosensor_temperature;
real xmin;
real xmax;
real ymin;
real ymax;
real zmin;
real zmax;
real x,y,z;
real nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
xmin=0.115;
xmax=0.135;
ymin=0.115;
ymax=0.135;
zmin=0.243;
zmax=0.250;
/* Begin loop to determine the temperature at the centroid of cells near the thermocouple */
nt=0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(thermosensor_coordinate,c,t);
x=thermosensor_coordinate[0];
y=thermosensor_coordinate[1];
z=thermosensor_coordinate[2];
if ((x >= xmin) && (x <= xmax))
if ((y >= ymin) && (y <= ymax))
if ((z >= zmin) && (z <= zmax))
printf("X-cord = %f\n",x);
printf("y-cord = %f\n",y);
printf("Z-cord = %f\n",z);
thermosensor_temperature=thermosensor_temperature + C_T(c,t); /* get thermocouple temperature */
printf("thermosensor_temperature = %f\n",thermosensor_temperature);
nt=nt+1.0; /* count number */
printf("value_nt = %d\n",nt);
end_c_loop(c,t)
thermosensor_temperature=thermosensor_temperature/nt;
printf("final_temp = %f\n",thermosensor_temperature);
thermosensor = thermosensor_temperature;
DEFINE_SOURCE(heater,c,t,ds,eqn)
real cutoff_temperature;
real source;
cutoff_temperature = 301.0;
if (thermosensor <= cutoff_temperature)
source = 327680;
return source;
else
source = 0;
return source;
I am interpreting the whole program using define>user-defined>functions>interpreted...it was successful without errors.
now it was showing two things,one is udf tsensor and second one is udf heater
I got confusion here regarding two things,
1. for function hook option..i selected both udf tensor and udf heater as execute at end
2. In cell zone conditions, selected udf heater for required domain
while doing above things, i got the below error..
chip-exec: heater: wrong return type: void udf function expected
Would like to know the above interpretation procedure was correct or any suggestions
Thanks in advance
hariswch2 is offline   Reply With Quote
Old   September 16, 2015, 02:23
Surya
now i modified interpretation procedure as follows
1. for function hook option..selected udf tensor only as execute at end
2. In cell zone conditions, selected udf heater for required component
Error "chip-exec: heater: wrong return type: void udf function expected" was not showing..it is working fine...but still. the temperature is keep on increasing mode only i.e., heater on only......it was not getting off after cutoff temp also...
Plz give suggestions....
Thanks in advance.....
Old   May 26, 2016, 12:52
Default UDMs
  #23
johnr
Johnr is on a distinguished road
I have the same problem...How can I access the temp calculated in the first macro for using it in the second macro. Please tell....
I am new to udfs and need the solution URGENTLY!!
Johnr is offline   Reply With Quote
Old   May 26, 2016, 12:57
Surya
Hi johnr..
Below was the working program for 3 cycles of heater on and off using IF condition
#include "udf.h"
real thermosensor_temperature1;
real x;
real xmin;
real xmax;
real ymin;
real ymax;
real zmin;
real zmax;
real x,y,z;
int nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
xmin=0.115;
xmax=0.135;
ymin=0.115;
ymax=0.135;
zmin=0.246;
zmax=0.250;
thermosensor_temperature=0.0;
/*thermosensor_temperature1=300.0;*/
nt=0;
thread_loop_c(t,d)
begin_c_loop(c,t)
/*printf("X-cord = %f\n",x);*/
/*printf("y-cord = %f\n",y);*/
/*printf("Z-cord = %f\n",z);*/
end_c_loop(c,t)
thermosensor_temperature1=thermosensor_temperature ;
printf("final_temp = %f\n",thermosensor_temperature1);
real source;
if(thermosensor_temperature1 == 300.0)
x=1.0;
if (x == 1.0)
if(thermosensor_temperature1>=300.0)
x=2.0;
source = 327680;
else if (x == 2.0)
if(thermosensor_temperature1>=300.0 && thermosensor_temperature1<=305.0)
source = 327680;
else
x=3.0;
source = 0;
else if (x == 3.0)
if(thermosensor_temperature1>=305.0 && thermosensor_temperature1<=306.0)
source = 0;
else if(thermosensor_temperature1>=302.0 && thermosensor_temperature1<=305.0)
source = 0;
else
x=4.0;
source = 327680;
else if (x == 4.0)
source = 327680;
else
x=5.0;
source = 0;
else if (x == 5.0)
source = 0;
source = 0;
else
x=6.0;
source = 327680;
else if(x == 6.0)
source = 327680;
else
x=7.0;
source = 0;
else if(x == 7.0)
source = 0;
source = 0;
else
x=8.0;
source = 327680;
else
source = 327680;
else
x=9.0;
source = 0;
return source;
Hope it will be useful to you...
Any queries let me know..............
Old   May 26, 2016, 13:12
Default UDMs
  #25
johnr
Thanks hariswch2,
But the variable thermosensor_temperature1 is not accessible in DEFINE_SOURCE. i.e. whatever change has happened in the value of thermosensor_temperature1, is not carried in the DEFINE_SOURCE macro.
Old   May 26, 2016, 20:14
`e`
`e` is on a distinguished road
If you define thermosensor_temperature1 outside of the DEFINE_SOURCE and other macros then this variable is global and accessible throughout the compiled UDF. hariswch2's code includes this declaration. Ensure you are not re-declaring or re-initialising the variable within other macros.
hariswch2 likes this.
`e` is offline   Reply With Quote
Old   May 27, 2016, 01:18
Surya
I support Mr "e" reply..thermosensor_temperature1 is declared as global variable, so it carries all over the program
Old   May 27, 2016, 02:07
Default UDFs
  #28
johnr
yes i know, that being a global variable it should be accessible in every macro.
below is my code-
#include "udf.h"
real outlet_temperature1;
/* Obtain the mean temperature at the outlet location */
/* outlet point located at coordinates (x,y,z) = (0.254085,0.130187,0.00226474) */
DEFINE_EXECUTE_AT_END(toutlet)
real outlet_coordinate[ND_ND];
real outlet_temperature;
real xmin;
real xmax;
real ymin;
real ymax;
real zmin;
real zmax;
real x,y,z,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
xmin=0.253;
xmax=0.255;
ymin=0.130;
ymax=0.132;
zmin=0.0022;
zmax=0.0023;
outlet_temperature=0.0;
nt=0.0;
/* Begin loop to determine the temperature at the centroid of cells near the outlet location */
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(outlet_coordinate,c,t);
x=outlet_coordinate[0];
y=outlet_coordinate[1];
z=outlet_coordinate[2];
outlet_temperature=outlet_temperature + C_T(c,t); /* get outlet temperature */
end_c_loop(c,t)
outlet_temperature=outlet_temperature/nt;
outlet_temperature1=outlet_temperature;
DEFINE_SOURCE(xmom_source,c,t,dS,eqn)
real source;
if (outlet_temperature1<=296)
source=-113013699.0;
else
source=0.0;
dS[eqn]=0.0;
return source;
__________________________________________________ _____
Now I have taken a 2D case in with the x momentum source term is regulated by the temperature at a particular location in the domain.
But the code is not working as desired. The source is having 0.0 value throughout the time, even if the temperature of the location went below 296.
The initial patched temperature is 298.
Please help....
Old   May 27, 2016, 05:28
`e`
First, check if you're getting the correct average temperature at outlet and if this value is being passed through to the source macro. Use the Message() function, for example:
outlet_temperature1 = outlet_temperature;
Message("outlet_temperature1 = %e\n",outlet_temperature1);
	real source;
	Message("outlet_temperature1 from DEFINE_SOURCE = %e\n",outlet_temperature1);
	else
		source=0.0;
	Message("source from DEFINE_SOURCE = %e\n",source);
	dS[eqn]=0.0;
	return source;
Note: use a trailing dot on real values to avoid erroneous type casting. You were comparing a real value with an integer:
if (outlet_temperature1<=296.)
Old   May 27, 2016, 12:20
Default UDfs
  #30
johnr
Hi 'e',
Thanks for your reply...
I am getting this message for every iteration,
outlet_temperature1 =-1.#IND00e+00
outlet_temperature1 from DEFINE_SOURCE = -1.#IND00e+00
source from DEFINE_SOURCE = 0.000000e+00
I think the Execute_at_end macro is not calculating the outlet temperature correctly....and i am not getting a hint to what should i do??
Old   May 27, 2016, 13:26
Default UDFs
  #31
johnr
I have increased the dimension ranges i.e. xmin, xmax...etc and now it is calculating the temperatures correctly....
And also the source is working properly...
Thank you so much...without all the help it would not be easy!
Old   May 27, 2016, 18:47
`e`
You could loop over the boundary faces on the outlet surface to find the average outlet temperature (example code). Then, you only need to specify the outlet boundary, rather than the tedious cell coordinates:
t=Lookup_Thread(d,11); // 11 is the outlet boundary ID (from GUI under boundary conditions)
Old   June 5, 2016, 16:35
Default Fixed Velocity in cell zone
  #33
johnr
I am trying to fix the axial velocity in a cell zone but getting error of pressure divergence. I have tried everything but can't solve the problem.
I am doing a 3D analysis of flow in two tanks connected by two pipes. One pipe has this small cylindrical cell zone(made by slicing operation) in which i am trying to fix the velocity. Putting a x momentum source term is working perfectly fine though.
Please help!
free stream temperature qzhu FLUENT 5 June 10, 2015 04:55
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 05:56
field function to point variable temperature Trofrensis STAR-CCM+ 1 November 25, 2009 01:46
Static temperature David FLUENT 2 April 1, 2005 11:57
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
