Can I use UDF function to solve this problem? |
zhuliang
Rep Power: 15 ![]() |
I want to simulate the process of the methane flow into a dynamic mesh. I hope the methane flows into the cylinder of dynamic mesh when the mesh has moved for a few seconds(the deformation of cylinder can form turbulence), that means I have to control the timing and duration of methane flow. Can I use UDF to define a inlet boundry to do this thing?
Thank you in advance |
Bernhard
Rep Power: 22 ![]() |
Yes, I suppose a DEFINE_PROFILE will do.
zhuliang
You means I have to define a periodic pressure profile in udf?
Bernhard
I don't know your precise set-up (concentration, two-fluid or?), but in general you can control your boundary condition in time and space using a DEFINE_PROFILE UDF. You can check the UDF Manual for some examples.
Parallel UDF problem | Lindsay | FLUENT | 4 | June 20, 2016 09:37 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
UDF using problem, error happens-heip!! | Michael | FLUENT | 1 | December 9, 2008 07:51 |
problem in compoile UDF | h.daniyel | FLUENT | 5 | June 12, 2008 05:06 |
C_NNODES UDF 'function' problem | Matthew Brannock | FLUENT | 2 | June 21, 2000 22:46 |
