identify interface boundary nodes in parallel
Old   September 30, 2010, 00:11
Default identify interface boundary nodes in parallel
Eric Doran
emdoran is on a distinguished road
I'm trying to find a way to identify whether a node is on an interface with another processor such that if I wanted to export a node list I could avoid duplicate nodes. I tried using BOUNDARY_NODE_P(n) and INTERFACE_NODE_P(n), however, the first gives all boundary nodes (including those not on the interface) and the second doesn't appear to ever be true.
I have also tried looping over the faces on each processor and determining whether it's a PRINCIPAL_FACE_P(f,t) and then marking the nodes to prevent them being counted twice, however there will still be duplicate nodes from the edges that are shared along the processor partition. Any insight or knowledge of an internal function to identify the interface nodes would be appreciated.
emdoran is offline   Reply With Quote
interface, node coordinates, nodes, parallel
Issue with running in parallel on multiple nodes daveatstyacht OpenFOAM 7 August 31, 2010 18:16
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
Defining UDS at interface, Boundary Zone Walls Sliding Mesh jalarron Fluent UDF and Scheme Programming 0 June 23, 2010 05:58
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 21:46
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
