error: uninitialized local variable 't' used
Old   September 22, 2010, 00:19
Default error: uninitialized local variable 't' used
MASOUD
MASOUD is on a distinguished road
I get the following error:
warning C4700: uninitialized local variable 't' used
warning C4700: uninitialized local variable 'c' used
When I compile the UDF (for line 65)
What could be the reason?
Here is the code:
#include "udf.h"
#include "sg.h"
/* Define which user-defined scalars to use. */
enum
E_CHARGE_UDS,
C_CHARGE_UDS,
N_REQUIRED_UDS
static real ACT_AREA_A=270;
static real ACT_AREA_C=300;
static real REF_EXCH_CURR_A=2.1;
static real REF_EXCH_CURR_C=0.40;
static real REV_POT=1.02;
static real MW_H2=0.032;
static real MW_H2O=0.032;
static real MW_O2=0.032;
static real MW_CO2=0.044;
static real MW_N2=0.032;
static real MW_MIX;
static real X_H2;
static real X_H2O;
static real X_O2;
static real X_CO2;
static real X_N2;
static real ALPHA_A=1.5;
static real ALPHA_C=0.5;
static real NO_ELEC=2;
static real FARADAY=96485;
static real UNI_GAS_CONS=8.314;
static real STOCH_H2=-1;
static real STOCH_H2O=1;
static real STOCH_O2=-0.5;
static real STOCH_CO2_A=1;
static real STOCH_CO2_C=-1;
static real RXN_RATE_A;
static real RXN_RATE_C;
static real Z_A;
static real ZZ_A;
static real ZZZ_A;
static real Z_C;
static real ZZ_C;
static real ZZZ_C;
static real source;
static real u=0.0;
static real domain_ID=30;
DEFINE_ADJUST(SUR,d)
u+=0.001;
DEFINE_ADJUST(UDM,d)
Thread *t;
cell_t c;
MW_MIX=MW_H2*C_YI(c,t,0)+MW_O2*C_YI(c,t,1)+MW_CO2* C_YI(c,t,2)+MW_H2O*C_YI(c,t,3)+MW_N2*C_YI(c,t,4);
X_H2=C_YI(c,t,0)*MW_H2/MW_MIX;
X_O2=C_YI(c,t,1)*MW_O2/MW_MIX;
X_CO2=C_YI(c,t,2)*MW_CO2/MW_MIX;
X_H2O=C_YI(c,t,3)*MW_H2O/MW_MIX;
X_N2=C_YI(c,t,4)*MW_N2/MW_MIX;
Z_A=ACT_AREA_A*REF_EXCH_CURR_A*(pow((X_H2),0.25));
ZZ_A=exp((ALPHA_A*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t)));
ZZZ_A=exp(-(ALPHA_C*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t)));
RXN_RATE_A=Z_A*(ZZ_A-ZZZ_A);
C_UDMI(c,t,0)=RXN_RATE_A;
Z_C=ACT_AREA_C*REF_EXCH_CURR_C*pow(X_O2,0.375)*pow (X_CO2,(-1.25));
ZZ_C=exp((ALPHA_A*FARADAY*(-(C_UDSI(c,t,0)-C_UDSI(c,t,1)-REV_POT)))/(UNI_GAS_CONS*C_T(c,t)));
ZZZ_C=exp(-(ALPHA_C*FARADAY*(-(C_UDSI(c,t,0)-C_UDSI(c,t,1)-REV_POT)))/(UNI_GAS_CONS*C_T(c,t)));
RXN_RATE_C=Z_C*(ZZ_C-ZZZ_C);
C_UDMI(c,t,1)=RXN_RATE_C;
MASOUD is offline   Reply With Quote
Old   June 23, 2011, 18:53
aleisia is on a distinguished road
Hi, have you figured out the way to eliminate the
"warning C4700: uninitialized local variable 't' used
warning C4700: uninitialized local variable 'c' used"?
I have the same problem in mu UDF, can you please share your experience with me?
Thanks!
Originally Posted by MASOUD View Post
Here is the code:
#include "udf.h"
#include "sg.h"
enum
E_CHARGE_UDS,
C_CHARGE_UDS,
N_REQUIRED_UDS
static real MW_MIX;
static real X_H2;
static real X_H2O;
static real X_O2;
static real X_CO2;
static real X_N2;
static real Z_A;
static real ZZ_A;
static real ZZZ_A;
static real Z_C;
static real ZZ_C;
static real ZZZ_C;
static real source;
static real u=0.0;
u+=0.001;
Thread *t;
cell_t c;
aleisia is offline   Reply With Quote
Old   June 24, 2011, 01:59
MASOUD
Yes, I had not included the looping macro.
Here is the corrected version of the above UDF with some changes:
DEFINE_ADJUST(CUR_DEN_A,d)
cell_t c;
Thread *t= Lookup_Thread(d,ID_A);
double CURR_D_A;
double Z_A;
double ZZ_A;
double ZZZ_A;
double OV_P_A;
double MW_MIX_A;
double X_H2;
double X_H2O;
double X_CO2_A;
if (FLUID_THREAD_P(t))
begin_c_loop(c,t)
/*MW_MIX=(C_R(c,t)*UNI_GAS_CONS*C_T(c,t))/C_P(c,t);*/
MW_MIX_A=1/((C_YI(c,t,0)/MW_H2)+(C_YI(c,t,2)/MW_CO2)+(C_YI(c,t,3)/MW_H2O)
X_H2=C_YI(c,t,0)*MW_MIX_A/MW_H2;
X_CO2_A=C_YI(c,t,2)*MW_MIX_A/MW_CO2;
X_H2O=1-(X_CO2_A+X_H2);
Z_A=ACT_AREA_A*REF_EXCH_CURR_A*(pow((X_H2),0.25))* (pow((X_H2O),0.25))*(pow((X_CO2_A),0.25));
OV_P_A=C_UDSI(c,t,0)-C_UDSI(c,t,1);
ZZ_A=exp(ALPHA_AA*FARADAY*OV_P_A/(UNI_GAS_CONS*C_T(c,t)));
ZZZ_A=exp(-ALPHA_CA*FARADAY*OV_P_A/(UNI_GAS_CONS*C_T(c,t)));
CURR_D_A=Z_A*(ZZ_A-ZZZ_A);
C_UDMI(c,t,13)=OV_P_A;
C_UDMI(c,t,14)=Z_A;
C_UDMI(c,t,15)=ZZ_A;
C_UDMI(c,t,16)=ZZZ_A;
C_UDMI(c,t,0)=u*CURR_D_A;
end_c_loop(c,t)
Old   November 26, 2012, 06:24
Kanarya is on a distinguished road
hi,
I have the same error with following code:
#include "udf.h"
DEFINE_EXECUTE_AT_END(measure_mass_flow)
float mass_flow, abs_v;
Domain *d;
Thread *t;
cell_t c;
mass_flow=0.;
/* Get the domain 1 (Mixture) */
d = Get_Domain(1);
abs_v=sqrt(C_U(c,t)*C_U(c,t)+C_V(c,t)*C_V(c,t));
thread_loop_c(t, d)
if( THREAD_ID(t) == 5 )
begin_c_loop(c, t)
mass_flow+=C_R(c,t)*abs_v ;
mass_flow=C_UDMI(c,t,0);
end_c_loop(c,t)
printf("mass_flow in outlet:%f/n",mass_flow);
can you help me?
thanks in advance!
Kanarya is offline   Reply With Quote
Old   October 14, 2016, 05:59
Default hi
SARA
SARAHAVASHI is on a distinguished road
i have the same problem with my code
can u help me?
thanks.
here is my code:
#include "udf.h"
DEFINE_PROFILE(slip_ncond_x,face_thread,i)
// x velocity for non conductive wall
real zeta_p;
Thread *t;
cell_t c;
zeta_p = -0.2*(C_T(c, t) - 273) - 78.2;
face_t f;
cell_t neig;
Thread *cell_thread;
Domain *domain = Get_Domain(1);
real vel,normal_magnitude,E_normal_x,E_normal_y,E_repai red_x,E_repaired_y;
real NV_VEC(A);
real mu=0.001003;
real eps0=8.85e-12;
real eps=80.1;
//cell_thread=THREAD_T1(face_thread);
cell_thread=THREAD_T0(face_thread);
begin_f_loop(f,face_thread)
neig=F_C0(f,face_thread);
// Repair E component values............................................ .................................................. ...
F_AREA(A,f,face_thread);
//Message("x is %g\n", A[0]);
normal_magnitude=pow( pow(A[0],2)+pow(A[1],2),0.5);
if ( NULL != THREAD_STORAGE(cell_thread,SV_UDS_I(0)) && NULL != T_STORAGE_R_NV(cell_thread,SV_UDSI_G(0)) )
E_normal_x=ND_DOT(-C_UDSI_G(neig,cell_thread,0)[0],-C_UDSI_G(neig,cell_thread,0)[1],0,A[0],A[1],0)/pow(normal_magnitude,2)*A[0];
E_normal_y=ND_DOT(-C_UDSI_G(neig,cell_thread,0)[0],-C_UDSI_G(neig,cell_thread,0)[1],0,A[0],A[1],0)/pow(normal_magnitude,2)*A[1];
E_repaired_x=-C_UDSI_G(neig,cell_thread,0)[0]-E_normal_x;
E_repaired_y=-C_UDSI_G(neig,cell_thread,0)[1]-E_normal_y;
else
E_repaired_x = 0 ;
F_PROFILE(f,face_thread,i)=-eps0*eps*zeta_p*E_repaired_x/mu;
end_f_loop(f,face_thread)
SARAHAVASHI is offline   Reply With Quote
Old   October 17, 2016, 05:24
Zbynek is on a distinguished road
You are trying to use thread t in C_T(c,t) but the program does not know what t is since you did not specify it anywhere. If you want to access temperature value C_T(c,t) in every cell of a thread (which I suppose you would like to do), then you need to use looping macro begin_c_loop(c,t) first which will loop over all cells of a specified thread. And you need to specify the thread still. Maybe cell_thread is what you want to use?
Zbynek is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
