August 28, 2010, 07:11 |
Use flow fild, but calculate only UDS
Timur
Rep Power: 16 |
Is it possible to solve equations for UDS by UDF without flow calculation
but with flow field from previous FLUENT solution (with scaled mesh)? |
September 1, 2010, 06:23 |
Max
Rep Power: 17 |
you can easily disable the solution of momentum equations by unchecking "Flow" in the menue Solution Controls/Equations. Convective transport of your UDS will be computed based on this "frozen" velocity field.
cheers |
September 2, 2010, 07:10 |
Timur
Rep Power: 16 |
Thank you very much. That helped a lot.
How to calculate particle mass flow rate at outlet | Randy | FLUENT | 6 | April 29, 2020 14:47 |
[OpenFOAM] How to calculate the fluid flow through a surface | lynx | ParaView | 4 | January 20, 2016 12:58 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
how to calculate CFL number in 3D convection-diffusion channel flow | dryhill | Main CFD Forum | 0 | June 24, 2009 04:33 |
How to solve UDS in Multiphase flow | Tim | FLUENT | 0 | March 6, 2007 04:33 |
