Help please! UDF for Temperature profile in 3D |
August 16, 2010, 02:42 |
Subhankar
Rep Power: 16 |
Hi all,
I am using UDF to define temperature field in 2D fluid flow problem. If I would like to put 3D temperature profile , what modification of UDF for 2D temperature profile is required. My UDF for 2D temperature profile is : DEFINE_PROFILE(inlet_temp, thread, index) { real x[ND_ND]; real temp, y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; temp = (12285-333)*(1-(pow((y/0.0035),4)))+(333); F_PROFILE(f, thread, index) = temp; printf("Temperature calculated by UDF is %f\n",temp); } end_f_loop(f, thread) } what would be for 3D? Thanks in advance. |
August 16, 2010, 06:23 |
Max
Rep Power: 17 |
If your inlet is a face aligned with yz-plane and temperature varies in both directions get the z-coordinate using x[2] and define your profile as function of both, y and z.
cheers |
August 16, 2010, 09:37 |
Modification in UDF for temperature profile for 3D geometry
Subhankar
Rep Power: 16 |
Hi Max,
Thanks for your suggestion. I have made modification according to your suggestion. Modified UDF for 3D geometry is given below please let me know whether it is ok. begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; z = x[2]; r = sqrt(pow(y,2)+pow(z,2)); F_PROFILE(f, thread, index) = (12285-333)*(1-(pow((r/0.0035),4)))+(333); } end_f_loop(f, thread) } Thanks again. |
please help UDF for velocity profile in y-directio | raju | Fluent UDF and Scheme Programming | 6 | April 13, 2019 00:21 |
3D UDF Paraboilc Velocity Profile (Can't Maintain) | Sing | FLUENT | 12 | August 7, 2017 07:25 |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 20:08 |
UDF parse error at profile function line | Wiggy | Fluent UDF and Scheme Programming | 1 | July 27, 2009 16:59 |
Associating profile files for the UDS though a UDF | Bharath | FLUENT | 0 | December 1, 2006 16:58 |
