A question about the access of properties?
Old   June 27, 2010, 02:45
Default A question about the access of properties?
zouzheng
zouzhengkaoyan is on a distinguished road
Hello! In the UDF of Fluent, is there any difference among the macro of MATERIAL_PROP( , ),generic property (name,c,t,prop,id,T)and C_***(c,t),such as MATERIAL_PROP(sp,PROP_RHO),generic property (name,c,t,PROP_RHO,id,T) and rho_s= C_R(cell, htread_s)?
Thank you in advanced!
zouzhengkaoyan is offline   Reply With Quote
Old   July 2, 2010, 18:28
TDi
Tim Diller
TDi is on a distinguished road
I think those must be the same thing. They're all macros defined by Fluent.
TDi is offline   Reply With Quote
Old   July 5, 2010, 00:11
zouzheng
Thank you ! May be they are the same, but I find the results are not same using different macro!
Old   October 31, 2014, 02:56
Georgy
gera is on a distinguished road
Hello!
As far as I can judge, the difference is following.
MATERIAL_PROP(sp,PROP_mu) returns the value of viscosity if it is constant. If we use power dependence on temperture the returned value is zero.
generic_property(c,t,PROP_mu,i,T) takes into account temperature in cell c; so we can use viscosity as a function of temperature, but I found that it does not work for power-law option. At the same time, it works well for polynomial option.
Does anybody know how to get viscosity of mixture component if viscosity has the power-law option?
Thank you!
gera is offline   Reply With Quote
Old   October 31, 2014, 08:40
ghost82's Avatar
Rick
ghost82 will become famous soon enough
If you can't access the mixture viscosity when it is set to power-law, what do you think of write the udf for mixture power-law viscosity, declare as a global variable the mixture viscosity so you can access it in other macros?
ghost82 is offline   Reply With Quote
Old   October 31, 2014, 08:49
Georgy
I've done it. Of course, it works fine, but if I change viscosity in GUI of Fluent, I need to change my udf. This is inconvinient. So the idea was to use fluent for viscosity calculation. In that case if user changes the viscosity law, for example, to "kinetic" then udf-code automatically uses new viscosity dependence (not necessary to re-compile).
Question of properties in two phase solver mmjhuang OpenFOAM Running, Solving & CFD 2 October 29, 2012 23:56
General question what fluid properties do you use harly OpenFOAM Running, Solving & CFD 0 November 18, 2008 16:38
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
Addiotional scalar properties: gas or liquid? Julie Polyakh Siemens 0 June 20, 2004 16:54
question K.L.Huang Siemens 1 March 29, 2000 05:57
