Udf for a transient analisys of a VAWT
Old   June 25, 2010, 05:33
Default Udf for a transient analisys of a VAWT
ermes is on a distinguished road
I' working with a vertical axis wind turbine; i made static analisys and i've used MRF method but i'm not satisfied of my result.
Now i'm trying to write an udf and use the six dof solver to do this:
-define the axis of rotation (y) and the mass property of the model
-calculate at every substep of a transient analisys:
-moment generate by wind
-increment of velocity due to the difference between the moment generated by wind and that of the generator.
Can everybody help me?
Thanks.
ermes is offline   Reply With Quote
Old   June 27, 2010, 20:50
Default need help for VAWT simulation
SOhail
sohail_27 is on a distinguished road
I am trying to run simulation (2D) for 3 bladed NACA 0012 airfoil in vertical motion with respect to central axis using gambit and fluent. I know how to create mesh for single airfoil and run simulation on it, but i don't know how to create mesh for airfoil and to rotate it in fluent. I would be glad if anyone could help me out.
Here is a youtube video of what i actually want to do. Please help me out guys, its part of my thesis.
http://www.youtube.com/watch?v=1eyEtzdHDEE
Regards.
sohail_27 is offline   Reply With Quote
Old   July 13, 2010, 18:07
SOhail
Hi Davesmith, i wish i could help you but i dont have mesh file for a cylinder, i am dealing purely with airfoils
Old   July 13, 2010, 18:27
Herman
enry is on a distinguished road
Hi all;
you have to create a sliding interface... have you created it?
enry is offline   Reply With Quote
Old   July 13, 2010, 18:30
SOhail
i have created the sliding meshes, and also got to see meshes rotatting, but at the interface region, i see a huge numerical noise (vortex shedding) how can i get rid of that???
Old   July 13, 2010, 18:37
Herman
what type of solver do you use? the best is K-epsilon realizable, K-W sst, or RSM.
However, near sliding interface the solution is not so good, so you have to put your interface far from the vawt. I use a box of 60xVawt Radius, and interface have a diameter of 10xVawt radius , and it work well. Try to re-mesh and use more cells near interface.
Old   July 13, 2010, 18:39
Herman
PS. How many revolution do you set to calculate your coefficient?
Keep in mind that solution will converge after 15-20 vawt revolution.
Old   July 13, 2010, 18:44
Herman
Sorry, i read that you are doing a static analisys. What type of coefficient would you like to obtain from static analysis? The static torque? To obtain the correct power coefficient you have to do a unsteady simulation...
Old   July 13, 2010, 19:09
SOhail
hi, i kept my interface at a distance of about 5*chord, @ this i observed error from inteface but was getting disappear after some time, should i keep them at more distance? i ran simulation with, K-e standard, RNG; K-w standard, SST, but i dint observed vortex shedding from blade, even though they appear they disappear before blade enters downwind condition, using S-A model, there was some shedding but even that disappear quickly? i am looking for a case where i can understand where the vortex shedding is maximum and where is the maximum interaction of the blade and shed vortices, which model will work good for that?
Old   July 13, 2010, 19:27
Herman
which type of error do u observe?
Every model you mentioned should be good...maybe you have to compare some results with experimental data...however, you should observe vortex shadding at the blades...
Old   July 13, 2010, 19:51
SOhail
yes i did observe some vortex shedding @ blade, but it got disappear as soon as blade moved to the next position, how can i account for blade vortex interaction then?
Old   July 14, 2010, 03:55
Herman
mmm...it's look like an update error... but, does fluent report any errors? Do you set properly b.c.?
Old   July 14, 2010, 14:35
SOhail
yes, i gave proper BC, fluent dint gave any error
Old   July 14, 2010, 16:32
Herman
Hi sohail_27, what do u mean saying : "i did observe some vortex shedding @ blade, but it got disappear as soon as blade moved to the next position" . The next position is the delta-angle of rotation? Maybe i don't undestand very well your problem, because you posted first: "I am trying to run simulation (2D) for 3 bladed NACA 0012 airfoil in vertical motion with respect to central axis using gambit and fluent". What do u mean saying: in vertical motion? How can you move the vawt vertically if the model is 2d?
Old   July 14, 2010, 17:12
SOhail
Hi enry,
I am doing 2-d simulation with NACA 0012 airfoil in circular motion. I have a circle( stationary wall) at center which would be the top view of vertical shaft. I started my simulation with single airfoil, after getting good results from single airfoil ill go for three airfoil system. I need to study about the blade and vortex interaction to minimize them.
i created the mesh file for it, but during simulation i observe numerical noise( in form of vortex shedding) from the interface region. How should i tackle this problem?
Parallelizing Transient UDF eliasmontoya FLUENT 2 October 20, 2009 10:47
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 07:47
spatial and transient B.C. using UDF Park FLUENT 0 April 28, 2005 22:32
initial conditions with transient UDF Antoine Pages FLUENT 4 September 19, 2004 12:51
UDF for transient boundary condition? Shankar FLUENT 1 November 22, 2003 09:10
