UDF for modelling heat loss in 2D
Old   June 18, 2010, 02:54
Default UDF for modelling heat loss in 2D
Shrinand Iyer
Shrinand is on a distinguished road
HI. I need help on how to construct a UDF, which can account for heat loss in a 2D channel. Thus effectively it will model 3D results from the 2D.
More details-http://FastFreeFileHosting.com/file/40127/UDf-bmp.html
Shrinand is offline   Reply With Quote
Old   February 29, 2016, 06:47
Default heat loss through walls
s.p.gupta
shri2802 is on a distinguished road
#include "udf.h"
#include "math.h"
#include "sg.h"
DEFINE_PROFILE(HTCh, t, i)
face_t f;
Thread *tco;
cell_t co; /**thread data**/
real Tc=0; /**centraoid temperature of cells **/
real Ts2=0; /** secondary side temperature for Grashof no **/
real q=0; /** heat flux at face **/
begin_f_loop(f, t)
Ts = F_T(f,t);
co =F_C0(f,t);
tco=THREAD_T0(t);
Tc=C_T(co,tco);
BOUNDARY_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0);
area = sqrt(A[0]*A[0]+A[1]*A[1]+A[2]*A[2]);
theta=area/A_by_es;
q=kl*abs(cos(theta))*(Tc-Ts)/ds;
Ts2=Ts-(log(d/di)*q*di/(2*ki)); //for cylinder
// Ts2=Ts- abs(dt*q/ki); // for rectangular slab
shri2802 is offline   Reply With Quote
Old   February 29, 2016, 06:50
s.p.gupta
This code will work better at solid meshed surface, but if u wish to use if fluid region you have to consider convective and transient energy terms too.
"Ts2" will give insulated body temperature, if u don't have insulation you can use directly "Ts" to calculate Gr number and using that u can relate with heat transfer coefficients.
UDF for wall heat flux ? Seyoung Oh FLUENT 6 August 4, 2018 06:44
Problem of heat balance in Coal Boiler simulation DG FLUENT 9 December 25, 2008 21:57
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 06:47
Specific Heat (Cp) cannot be calculated by UDF??? JoĆ£o Fernandes FLUENT 0 October 16, 2008 19:58
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 10:52
