enum
Old   June 5, 2010, 01:49
Default enum
MASOUD
MASOUD is on a distinguished road
Hi;
I need to define two scalars (UDS) and below you can find the UFDs for the aforementioned scalars.
I'm just wondering what does the "enum" do??? And shall I change anything?
UDS-01
#include "udf.h"
#include "sg.h"
/* Define which user-defined scalars to use. */
enum
E_CHARGE_UDS,
C_CHARGE_UDS,
N_REQUIRED_UDS
static real ACT_AREA_A=270000;
static real REF_EXCH_CURR_A=2.25;
static real MW_H2=0.002;
static real MW_CO2=0.044;
static real MW_H2O=0.018;
static real MW_MIX;
static real X_H2;
/*static real X_CO2;*/
/*static real X_H2O;*/
static real ALPHA_A=0.5;
static real ALPHA_C=1.5;
static real NO_ELEC=2;
static real FARADAY=96485;
static real UNI_GAS_CONS=8.314;
static real RXN_RATE_A;
static real Z;
static real ZZ;
static real ZZZ;
static real source;
DEFINE_SOURCE(ELECT_SOURCE_ANODE,c,t,dS,eqn)
MW_MIX=MW_H2*C_YI(c,t,0)+MW_CO2*C_YI(c,t,2)+MW_H2O *C_YI(c,t,3);
X_H2=C_YI(c,t,0)*MW_H2/MW_MIX;
/*X_CO2=C_YI(c,t,2)*MW_CO2/MW_MIX;*/
/*X_H2O=C_YI(c,t,3)*MW_H2O/MW_MIX;*/
Z=ACT_AREA_A*REF_EXCH_CURR_A*(pow((X_H2),0.25));
ZZ=exp((ALPHA_A*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t)));
ZZZ=exp(-(ALPHA_C*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t)));
RXN_RATE_A=Z*(ZZ-ZZZ);
source=-RXN_RATE_A;
dS[eqn]=0;
return source;
UDS-02
#include "udf.h"
#include "sg.h"
enum
E_CHARGE_UDS,
C_CHARGE_UDS,
N_REQUIRED_UDS
static real ACT_AREA_C=300000;
static real REF_EXCH_CURR_C=0.4;
static real MW_O2=0.032;
static real MW_MIX;
static real X_O2;
static real X_CO2;
static real ALPHA_A=1.5;
static real ALPHA_C=0.5;
static real RXN_RATE_C;
static real Z;
static real ZZ;
static real ZZZ;
static real source;
DEFINE_SOURCE(ELECT_SOURCE_CATHODE,c,t,dS,eqn)
MW_MIX=MW_O2*C_YI(c,t,1)+MW_CO2*C_YI(c,t,2);
X_O2=C_YI(c,t,1)*MW_O2/MW_MIX;
Z=ACT_AREA_C*REF_EXCH_CURR_C*pow(X_O2,0.375)*pow(X _CO2,(-1.25));
RXN_RATE_C=Z*(ZZ-ZZZ);
source=RXN_RATE_C;
dS[eqn]=0;
return source;
MASOUD is offline   Reply With Quote
what's mean enum in udf zhu FLUENT 3 May 6, 2024 04:24
