DEFINE_SDOF_PROPERTIES external moment
Old   May 26, 2010, 10:56
Default DEFINE_SDOF_PROPERTIES external moment
Randre is on a distinguished road
Hi all
I need to apply a new force / moment to my UDF file which describes the motion of an object: Mass matrix is defined and only zz rotation is allowed. This object is like a pendulum, doesn't rotate about it's CG.
Now I want to add a moment to the rotation point (defined in FLUENT dynamic mesh GUI, as CG). For that I want to apply the following macro: prop[SDOF_LOAD_M_Z],
but in this case my moment force changes with the rotation angle of the object, and FLUENT doesn't allow me to input the following function:
(-(mass*grav*L*sin(DT_THETA(dt)[2])*sin(DT_THETA(dt)[2])))-(-(mass*grav*L*cos(DT_THETA(dt)[2])*cos(DT_THETA(dt)[2])))
How can I add these force to DEFINE_SDOF_PROPERTIES ?
Thank you in advance
Randre is offline   Reply With Quote
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:51
viscous moment Thierry FLUENT 0 April 8, 2003 06:43
