Use DEFINE_ADJUST change boundary condition
Like Tree8Likes
Old   December 11, 2010, 09:49
TDi
Tim Diller
TDi is on a distinguished road
Click on my name to the left to send a private message. I do not wish to give out my email address. Thanks.
TDi is offline   Reply With Quote
Old   November 29, 2011, 07:01
Default 3D dynamic mesh tutorial
  #22
Darren Cam
darren_camilleri is on a distinguished road
Hi people,
I was attempting the 3D adiabatic compression tutorial with dynamic meshing and I haven't got the file cyl3d_new.msh. If anyone can send me the file please it will be greatly appreciated. Thanks.
My email: darren.camilleri90@gmail.com
darren_camilleri is offline   Reply With Quote
Old   March 1, 2013, 06:19
abdul quiyoom
quiyoom is on a distinguished road
Hi, I am trying to simulate the 3-D flow dynamics of bubble column (gas-liquid flow using euler-lagrange simulation) using FLUENT. I am filling only half the column with water and trying rest to patch with air.
Could anyone suggest the right way to patch gas-liquid in the bubble column? Also, how do you really model gas-liquid free surface flow in Bubble Column? Thanks.
I appreciate your help.
Quiyoom
quiyoom is offline   Reply With Quote
Old   June 21, 2014, 04:48
jyothsna k
jyothsna k is on a distinguished road
My problem is similar to the one discussed here. I need to specify the flux of scalars at the boundary. They are neither constant nor are they known before hand.
I followed the procedure suggested by you. I use the define_profile to initialise the flux value to zero and write the zone id and uds id to a file. This is happening.
I then access the corresponding files depending on the thread id, read the values from the files and use F_PROFILE to assign the flux values from stored memory.
I have used solve/set/expert to save the gradients.
When i hook the ADJUST udf and run, fluent shuts down.
What could be the problem?
Thanks in advance
jyothsna k is offline   Reply With Quote
Old   August 1, 2014, 11:28
Default Not using Fluent these days
  #25
TDi
Tim Diller
Hi, and thanks for the interest in this thread. I should let you know that I am not an active Fluent user anymore (for 3 years now) and will not be able to respond to further inquiry at present.
Old   August 3, 2022, 08:17
sina
sina_sls is on a distinguished road
Originally Posted by liurengtong123 View Post
Hi
thank you for giving me some suggestion.
I want to talk about my problem in detail ,so please give me your Email in order to discuss about it.
My Email :liurengtong@163.com
Thanks very much!!!
I want to change UDS boundary value i mean i want to use transient value , you know how can i do this with Define Adjust?
Regards,
sina_sls is offline   Reply With Quote
Old   October 4, 2023, 09:46
Xuxu is on a distinguished road
Regards,
do you get any information on your problems? My problem is the same as you. Thank you in advanced!
Xuxu is offline   Reply With Quote
Old   October 5, 2023, 04:23
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
use DEFINE_PROFILE macro
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 5, 2023, 07:54
Hello,Alexander
I need to apply the gradient of C_UDSI on the surface, does DEFINE_PROFILE work? I find that the GUI have two options, which is Flux and Value for UDS boundary condition.
Old   January 14, 2024, 01:56
Brett
Bdew8556 is on a distinguished road
Hey guys,
I'm working on something similar, was wondering if maybe you solved yours.
I've got a simple flow problem with:
INLET = Pressure
OUTLET = mass flow rate
at some location I've got a user surface where I can calculate flow velocity.
I want a UDF that can update the mass flow rate at the outlet based on the velocity calculated at the user surface.
Any thoughts? do I need to use the DEFINE_ADJUST macro?
Bdew8556 is offline   Reply With Quote
fluent, udf
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
How to change boundary condition from command fluent87 FLUENT 8 September 11, 2019 14:27
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 07:16
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
