Access parameter value from within DEFINE_PROFILE ???
Old   May 14, 2010, 18:21
Default Access parameter value from within DEFINE_PROFILE ???
TDi
Tim Diller
TDi is on a distinguished road
I'm working on a problem where I want to set the heat flux at a boundary based on the temperature at a specific point. I'm trying to simulate thermostatic control of a heater.
I generated a point surface using Surface>Point...
It shows up as a surface group with an id and name, but this is not a ZONE_ID.
I can create an output parameter (area averaged temperature) with Define>Parameters... but when I tried to access this with a Scheme macro (RP_Get_Value("parameter_name")) in the UDF, it failed.
How can I look up this temperature from within the UDF???
I would really appreciate any help anyone can give on this. Thanks!
TDi is offline   Reply With Quote
Old   May 17, 2010, 13:00
Francesco Capuano
francesco_capuano is on a distinguished road
Try to use:
RP_Get_Real("variable-name")
francesco_capuano is offline   Reply With Quote
Old   May 17, 2010, 16:07
fox000002's Avatar
fox000002 is on a distinguished road
Define>Parameters???
What is your fluent version?
fox000002 is offline   Reply With Quote
Old   May 17, 2010, 16:10
TDi
Tim Diller
I'm using v12.1
define_profile, scheme, udf
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
MAxium residual...confusion with expert parameter KK CFX 3 February 8, 2008 11:47
UDF Data Access Macro Woo Meng Wai FLUENT 0 November 6, 2007 21:23
Error: access: unbound variable,HELP sudhakar FLUENT 0 January 16, 2007 00:21
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 20:28
