entropy generation with UDF
Like Tree2Likes
Old   November 8, 2018, 13:40
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Originally Posted by mohammadkm View Post
Dear dragos
you solved my problem, thank for your help.
As you said there is no need to write udf, i just used "/solve/set/expert".
After that i changed criteria of energy from 1e-6 to 1e-12 and my solution was validated.
thanks again
Hello Mohd. Km
Could you please tell me your paper and which paper you are validating your results from?
Regards,
Shamoon Jamshed is offline   Reply With Quote
Old   June 10, 2020, 23:31
Default Calculation problem!
  #22
salih
m.salih is on a distinguished road
Send a message via MSN to m.salih Send a message via Skype™ to m.salih
Originally Posted by pakk View Post
There are two options:
- Fluent has a bug and calculates the square of the gradient of temperature wrong.
- You did something wrong when you tried to let Fluent calculate the square of the gradient of the temperature.
You seem to think that the second option is very unlikely. I think the first option is very unlikely.
Dear pakk, have you any idea about wrong entopy calculation? I have same problem now. The results of custom field function and excell calculations do not match, especially the square of gradient are different, do you have any advice? Thanks.
m.salih is offline   Reply With Quote
Old   June 10, 2020, 23:37
salih
Originally Posted by Ras0ul View Post
Dear all
I entered the entropy generation equation in custom field function.but my result is wrong(not validated with paper). I examined my results and found that Fluent calculate the temperature gradient, but it can not properly calculate the square of the temperature gradient!!!
please help with this problem
thanks
Dear Ras0ul, have you solved your problem about wrong entopy calculation? I have same problem now. The results of custom field function and excell calculations do not match, especially the square of gradient are different, do you have any advice? Thanks
UDF - volumetric heat generation Thiago Castro Fluent UDF and Scheme Programming 1 April 5, 2019 03:15
Entropy Generation in compressible flow Dave FLUENT 0 January 5, 2004 08:12
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 01:48
Latest new in mesh generation Robert Schneiders Main CFD Forum 0 February 16, 2000 08:12
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 05:07
