(DPM) Names for User Scalars (instead of Use Variable 0)?
Old   April 20, 2010, 07:27
Default (DPM) Names for User Scalars (instead of Use Variable 0)?
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I'm using a total number of 41 User Defined Scalars in my DPM-Iteration.
Is there a way to give these variables some other names than "User Variable 0" or "User Variable 23"?
This would be very usefull for (first) the distinction and (second) for the plots I'm plotting.
Any ideas?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 20, 2010, 07:51
Max
coglione is on a distinguished road
hi sega,
there is a macro called Set_User_Scalar_Name. Have a look in UDF-Manual chapter 3.2.8.
cheers
coglione is offline   Reply With Quote
Old   April 20, 2010, 08:09
sega's Avatar
Sebastian Gatzka
Originally Posted by coglione View Post
hi sega,
cheers
Hm, looks like this macro works only for "real" User Defined Scalars (UDS).
I'm just using user variables from within the DPM-Model I access with
P_USER_REAL(p,i)
I think this is not the same.
Old   April 20, 2010, 08:33
Max
I don't know, you have to try it out. However, if your intention is to make your code more readable for yourself, you might use enum to correlate a name with a specific index like this:
enum
myscalar
yourscalar
P_USER_REAL(p,myscalar) would then be equivalent to P_USER_REAL(p,0)
cheers
Variable names for mass flux for a recirculating-outlet boundary condition BRNN Fluent UDF and Scheme Programming 7 September 4, 2018 14:49
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
VARIABLE NAMES Alejandro A CFX 2 August 17, 2006 10:47
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
