Grid motion with UDF
Old   April 5, 2010, 09:49
Default Grid motion with UDF
Phoevos
fivos is on a distinguished road
Hi to everyone !
I am trying to simulate a moving grid using Fluent dynamic mesh. I have created a structured quad mesh and used layering as a dynamic meshing technique. The grid motion is set from the Dynamic mesh zones Create/Edit menu as User-defined and the UDF supplied is the following :
#include"udf.h"
DEFINE_GRID_MOTION(motion,domain,dt,time,dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(axis);
real displ;
int n;
displ=-17.2*dtime; // grid displacement
NV_D(axis, =, 0.0, 1.0, 0.0);
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
/* update node if the current node has not been previously
visited when looping through previous faces */
if ( NODE_POS_NEED_UPDATE (v))
/* indicate that node position has been update
so that it's not updated more than once */
NODE_POS_UPDATED(v);
NV_V_VS(NODE_COORD(v), =, NODE_COORD(v), +, axis,*,displ);
end_f_loop(f,tf);
This simple UDF was based on the DEFINE_GRID_MOTION example in the fluent 12 UDF manual. What it actually does is that it displaces the mesh on the Y-axis (axis : 0, 1,0), by -17.2 * time_step (17.2 is the mesh velocity).
The UDF compiles and loads and the mesh moves and new elements are generated/merged at stationary zones.
But my problem is that when I calculate the mesh velocity, by simply finding its displacement between two times, the mesh velocity is substantially lower than the one set in the UDF (~10m/sec instead of 17.2m/sec) !
What I am missing here? Any ideas are welcome.
Thank you in advance.
fivos is offline   Reply With Quote
Old   April 5, 2010, 11:44
Phoevos
I am posting myself because I found the cause of the problem. The problem was not the UDF at all, but the wrong time intervals for the extraction of the output data files.
Old   February 27, 2011, 05:51
Smile can you help me
fika
rafik10 is on a distinguished road
have you, sir , tutorials a bout this domain?
my boreblem is to similate fllaping NACA0012 in 2D of tow degree of 2 freedom.
I try to do it with moving gird mesh , but i cant do it .
please
email: bouakkaz10@yagoo.fr
rafik10 is offline   Reply With Quote
Old   December 24, 2016, 11:50
Smile Define_grid_motion
fatemeh
f.barikloo is on a distinguished road
hello everyone.
does anyone know how to write define grid motion udf with cylindrical coordinates?
thanks in advance.
f.barikloo is offline   Reply With Quote
Old   June 26, 2018, 04:07
Default tutorial
Saman95 is on a distinguished road
hello dear
can u give me a tutorial about grid motion dynamic mesh?
if u have an address link please send me.
thanks
Saman95 is offline   Reply With Quote
Old   June 30, 2018, 09:50
Originally Posted by fivos View Post
Hi to everyone !
#include"udf.h"
face_t f;
Node *v;
real NV_VEC(axis);
real displ;
int n;
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
end_f_loop(f,tf);
hello sir
Do you know the meaning of the bottom commands?
NODE_COORD(v)
please help me
thanks
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 10:16
udf for wall motion tseo Fluent UDF and Scheme Programming 1 June 14, 2012 18:57
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 15:17
Grid Macros for UDF elena FLUENT 0 May 9, 2006 09:44
UDF to change BC from Wall to Grid Line Aaron Smith FLUENT 0 February 21, 2006 10:14
