Please, Help with linking UDF precompiled outside fluent to fluent!!!
Old   April 4, 2010, 16:59
Thumbs down Please, Help with linking UDF precompiled outside fluent to fluent!!!
Grace Lima
gracerlima is on a distinguished road
People, anybody help me please!
I wrote an UDF for a sinusoidal pitching movement of a NACA0012 profile.
I didn't succeed compiling it from the graphical user interface (operational system: windows) and then I compiled it from the visual studio 2008 command prompt window. Both the udf.obj and the libudf.dll were successfuly created.
Then I proceed reading the UDF manual to make the procedure for linking precompiled objects from non-Fluent and it didn't work.
I went to the libudf directory as is asked in the UDF Manual and I wrote the command:
make "FLUENT_ARCH=ntx86"
and received the following answer:
make: *** No targets specified and no makefile found. Stop.
I would like to ask what should I do. Should I move the makefile to the libudf directory?
has anybody ever done this procedure before?
Thanks in advance for the help
gracerlima is offline   Reply With Quote
Old   May 4, 2010, 08:19
Nuno Gomes
Dinocrack is on a distinguished road
Hi gracerlima
Did you solve your problem? i have one identical....
How you solve the problem?
Regards
Dinocrack is offline   Reply With Quote
problem loading UDF in parallel fluent Tim FLUENT 12 July 12, 2008 13:59
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 25, 2006 00:09
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 04:07
