Read txt file and import values to source term.
Like Tree3Likes
Old   July 21, 2016, 18:20
Sagar
ksgr is on a distinguished road
Hello Micael!
I don't know what was the problem. I was able to find the solution when I started writing the code bit by bit and checking whether that code would compile in fluent. I reached a stage where whole code could compile with the proper messages of file read and closed. Thank you.
Now I have one doubt, currently DEFINE_ON_DEMAND, for which I have to manually assign the values read in from the file to arrays. Is there a macro which does this automatically as soon as the loading of the library is over?
ksgr is offline   Reply With Quote
array, file, source, txt, udf
How can I import a momentum source term from a dat May Huang FLUENT 1 September 5, 2011 06:50
help: How can I import a source? May Huang FLUENT 1 September 5, 2011 06:49
how do I import tecplot file to fluent Kangello FLUENT 0 December 2, 2009 09:28
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 14:22
