Does Fluent Calculate VOF before Momentum ?
Old   February 23, 2010, 04:28
Lightbulb Does Fluent Calculate VOF before Momentum ?
Ganapathy Iyer
Ganapathy is on a distinguished road
Hello Guys,
I am writing a UDF involving VOF. I want to calculate the VOF values using the UDF instead of the Fluent formulation. These values will then effect the momentum and continuity equations. My question is , while using a UDF with a Segregated solver, what gets calculated first? Is it the UDF functions or is it the Continuity, Momentum equations?
I am writing a UDF for the following paper :
"A Numerical Study of Combined Heat and Mass Transfer in an Inclined
Channel Using the VOF Multiphase Model
R. Banerjee - Mark IV Automotive, Enterprise Drive, Rochester Hills, Michigan, USA"
If anyone has a UDF or something similar to this, please share it with me
Ganapathy is offline   Reply With Quote
Old   April 7, 2010, 11:56
mengyue
mengyue1 is on a distinguished road
Originally Posted by Ganapathy View Post
Hello Guys,
yes, in your case, Fluent calculates Continuity, Momentum equations first.
And i am also wriing UDF for your paper described as above.
so will you contact me? my email is mengyue1@126.com...
mengyue1 is offline   Reply With Quote
segregated solver, udf, vof
VOF & Variable Surface Tension in FLUENT SeamusTCD FLUENT 13 June 18, 2022 02:51
Fluent VOF Steve FLUENT 8 September 23, 2016 13:40
Fluent VOF Volume of Fluid Realistic Solution Problem wormik FLUENT 3 June 21, 2009 08:04
Source Terms in Momentum Balance vidyaraja Main CFD Forum 0 May 25, 2009 16:24
FLUENT VOF for ship's hull simone b. Main CFD Forum 5 December 6, 2008 08:45
