A Problem of Fluent Interpreted UDF: parse error |
January 18, 2018, 09:26 |
[QUOTE=pakk;678565]You were able to find the "load" button. On the same screen, there
#21 |
wan zhihua
Rep Power: 9 |
January 19, 2018, 04:14 |
#22 |
Rep Power: 27 |
It depends on which errors comes on your screen after you click "build". I can not look at your screen.
Please read carefully: NOT the error that you get after clicking "load". That one you have shown me already. |
January 19, 2018, 13:26 |
#23 |
Rep Power: 12 |
On the wider question of learning UDFs and compiling UDFs:
-- Look at the help files and the tutorials. -- I recently made a list of the steps that you have to follow to compile a UDF: see The UDF library you are trying to load (libudf) is not compiled for 3D on the current. But if you have not read any help materials at all, then this list might not make any sense. -- When you compile, scroll back up and see if there are any compilation errors. If there are, you need to fix them before running the libudf. If they refer to specific lines in your input code, go and look at those lines. If they do not refer to your input code, something is wrong with your compiler setup -- check out pakk's helpful post from 2016: How to solve UDF compilation problems in Fluent. |
January 22, 2018, 23:11 |
[QUOTE=pakk;678658]It depends on which errors comes on your screen after you click "b
#24 | |
wan zhihua
Rep Power: 9 |
now these pictures are the build result,but there are some messy code on the screen,can you tell me what is the reason?thank you. IMG_5535.jpg IMG_5537.jpg |
January 23, 2018, 04:00 |
#25 | |
Rep Power: 27 |
Surprisingly: yes, I can.
You get the error message: Quote:
This means that your compiler is not set up correctly. Currently, your UDF code is not the problem. Solve this. Look for the error message on this forum to find out how, I am no expert on this. |
August 16, 2018, 11:26 |
#26 |
Ken
Rep Power: 8 |
I'm getting a parse error as well for my UDF file. I would really appreciate if anyone could help me with it.
UDF File: #include "udf.h" DEFINE_PROFILE(x_velocity_a,thread,nv) { float pos[3]; /* an array for the coordinates */ float y; face_t f; /* f is a face thread index */ begin_f_loop(f, thread) { F_CENTROID(pos,f,thread); y = pos[1]; F_PROFILE(f, thread, nv) = 1.-(400.*y-1.)*(400.*y-1.); } end_f_loop(f, thread) } Error, when using Interpreted UDFs: ....... line 15: parse error. Thank You! |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 07:43 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 19:54 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
