sharing the directory for parallel 6DOF udf....
Old   February 16, 2010, 13:37
Default sharing the directory for parallel 6DOF udf....
USMAN
usman naseer is on a distinguished road
hi everyone,,
i am simulating store separation in Fluent using 6DOF solver.The mesh size is 2.3 million and it is tetrahedral grid.Now the problem is if i run it on a single node, my system goes out of memory.So i have to use parallel processing.But in parallel processing,after 1st time step, i get the following error.
unable to read cmd header on pmi context:generic socket failure........
and
MPID_SOCK_WAIT:The specified network name is no longer available...
and befor that ,durine the compilation of udf,i get a warning as well i.e;
the specified directory is not shared.This may cause file opening issues across the network.
I am using Windows xp ,Quad node processor with 2 GB of ram.
Can anyone help me in this regard??
Regards
usman naseer is offline   Reply With Quote
sharing the directory for parallel 6DOF udf .... usman naseer FLUENT 0 February 16, 2010 13:29
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 20:09
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 11:19
