UDF. as always.
Old   December 7, 2009, 09:49
Lightbulb UDF. as always.
DmP
DmP's Avatar
Try Ratov
DmP is on a distinguished road
Hi all!
I am going to gain an understanding of UDF format. The case is the simplest: 2D tube with an actuator disk model inside. I want to use a DEFINE_SOURCE option to add x-momentum source. The disk has been marked as a separate zone in GAMBIT (width X – 1 cell, height Y – 10 cells).
When I use a constant profile like:
#include "udf.h"
#define CON 100.0
DEFINE_SOURCE(cell_x_source, c, t, dS, eqn)
real x[ND_ND];
real source;
C_CENTROID(x, c, t);
source = CON;
dS[eqn] = 0;
return source;
Everything is fine.
But for a linear or parabolic profile like:
#include "udf.h"
DEFINE_SOURCE(xmom_source,c,t,dS,eqn)
real x[ND_ND];
real source, y;
C_CENTROID(x,c,t);
y = x[1];
source = 100. - 100.*((.7-y)/.5)*((.7-y)/.5);
dS[eqn] = 0.0;
return source;
It doesn’t work – profile is not parabolic after calculations. (y-coordinate changes from 0.2 to 1.2 ).
Could you help me with such stupid problem? Thanks!
DmP is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
