Control flow with the geometry
Old   November 5, 2009, 20:06
Default Control flow with the geometry
Dung Si Diet Quy
dungsidietquy is on a distinguished road
(Black color = Wall. White color = solid particle. Blue color = liquid)
When I run the multiphase model (ex: Eulerian Multiphase Model), how can I programed the flow through the narrow hole.
If I don't program anything, the Fluent will solve this problem normally (large particle flow pass the smaller hole)---> the result isn't correct.
So I want to know how to make the Fluent know that if the diameter of particle is bigger than the width of the hole, there will be not the flow pass the hole, and the particle will flow back.
Thank you very much.
dungsidietquy is offline   Reply With Quote
LFC (Laminar Flow Control) Mojtaba Main CFD Forum 1 February 24, 2010 18:15
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Adaptive optimization of geometry Jan Rusås CFX 1 September 16, 2000 03:38
Virtual/Real geometry. Jack Keays FLUENT 9 June 16, 2000 00:39
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
