How to access only one phase in multiphase model by UDF
Old   September 23, 2009, 08:57
Default How to access only one phase in multiphase model by UDF
Soeren Werner
wersoe is on a distinguished road
Hello guys,
I am trying to write an UDF to write data (cell volume, spec diss rate) only for one phase in multiphase (vof) model.
However, either I get all cells or a segmentation violation error.
I tried different methods to access only primary_phase by threads or domains, but I do not have any success.
Could you help me please...
For checking, used a quader with 8000 cells, patched to water in 4000 cells.
I did and didnt run some iterations, nothing helps...
This UDF writes cell volume of all cells, not only primary phase
If I switch C_VOLUME to C_D for spec diss rate, a seg viol error aoccurs.
#include "udf.h"
DEFINE_ON_DEMAND(write_data)
  cell_t c;
  int ID = 2;
       /* Zone ID for wall-1 zone from Boundary Conditions panel */
  Domain *mixture_domain = Get_Domain(1);
  Domain *subdomain = DOMAIN_SUB_DOMAIN(mixture_domain,0);
  Thread *thread = Lookup_Thread(subdomain, ID);
  FILE *output=fopen ("epsilon.out","w");
  begin_c_loop(c, thread)
        fprintf(output,"\nvof=%e", C_VOLUME(c,thread));
  end_c_loop(c, thread)
fclose(output);
This UDF writes C_VOF for all cells, not only primary phase
eventhough C_VOF(c,pt[1])
#include "udf.h"
DEFINE_ON_DEMAND(print_vof)
Domain *mix_domain = Get_Domain(1);
Thread *mix_thread;
Thread **pt;
mp_thread_loop_c(mix_thread, mix_domain, pt)
cell_t c;
begin_c_loop(c, pt[1])
Message("cell volume fraction = %f\n",C_VOF(c,pt[1]));
end_c_loop(c, pt[1])
This UDF writes values for all cells too.
Eventhough if(C_VOF(cell,subthread) = 1)
#include "udf.h"
DEFINE_ON_DEMAND(print_id)
Domain *s_d = DOMAIN_SUB_DOMAIN(mixture_domain,0);		/*subdomain pointer, locally defined*/
Thread *mixture_thread;
cell_t cell;
int p_d; 		/* loop counter for phase_domain_index, locally defined*/
int p_d_id;		 /* mix_domain is available*/
fprintf (output, "energy dissipation rate distriubtion\n");
fprintf (output, "epsilon,volume\n");
int phase_domain_index=0;
sub_domain_loop(s_d, mixture_domain, phase_domain_index)
	/* loop over all cell threads in the primary phase domain  */
    		thread_loop_c(mixture_thread,s_d)
        		/*Thread *st = THREAD_SUB_THREAD(cell_thread, 0);*/
			/* loop over all cells in primary phase cell threads  */
	               	begin_c_loop(cell,mixture_thread)
			/*if(C_VOF(cell,mixture_thread) = 1)*/
			Message("\nDone... %g", C_VOF(cell,mixture_thread));
			fprintf(output,"\nDone...");
			end_c_loop(cell,mixture_thread)
fclose (output);
Eventhough I have 3 examples here, I would like to go to the first one, since I need Lookup_Thread for determining the size of an array to parallelize the udf.
Examplers for parallelizing are here: http://www.fluentusers.com/fluent/do...df/node231.htm
I do not know how I can to this when using a loop over domains or threads, since the size of the array needs to be send from nodes to host...
If I check the udf, it seems very clear to me: I define a domain, then a subdomain, then I define a thread by using subdomain for lookup...
That means, in thread it is supposed to point to thread in subdomian, or better to thread in domain with phase index 0...
However, C_VOLUME can be written, but C_D or C_VOF causes a seg viol error...
Actually, the task seems very easy to me.
Write cell values from cells which are associated with primary phase.
I have tried different methods to access one phase only.
However, I am at one's wit' end...
Any help is much appreaciated.
Thanks, Sören
wersoe is offline   Reply With Quote
Old   January 4, 2017, 08:11
Przemek
gaza is on a distinguished road
Originally Posted by wersoe View Post
Hello guys,
#include "udf.h"
  cell_t c;
  int ID = 2;
fclose(output);
#include "udf.h"
Thread *mix_thread;
Thread **pt;
cell_t c;
#include "udf.h"
cell_t cell;
fclose (output);
Thanks, Sören
Hi Soren,
Try this code:
DEFINE_INIT(my_init_function, domain)
  Thread *t;
  Thread **pt;
  Thread **st;
  cell_t c;
  Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE);
  Domain *sDomain = DOMAIN_SUB_DOMAIN(domain,S_PHASE);
  real xc[ND_ND], y, x;
      mp_thread_loop_c (t,domain,pt)
    if (FLUID_THREAD_P(t))
        Thread *tp = pt[P_PHASE];
        begin_c_loop (c,t)
     C_CENTROID(xc,c,t);
     x=xc[0];
      if ( x > 0.02)
      C_VOF(c,tp) = 0;
      else
      C_VOF(c,tp) = 1;
          end_c_loop (c,t)
               mp_thread_loop_c (t,domain,st)
        Thread *sp = st[S_PHASE];
        begin_c_loop (c,t)
     C_CENTROID(xc,c,t);
     x=xc[0];
      if ( x > 0.02 )
      C_VOF(c,sp) = 1;
      else
      C_VOF(c,sp) = 0;
          end_c_loop (c,t)
best regards
pblasiak
gaza is offline   Reply With Quote
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
Discrete phase or two phase model in Fluent? andrea panizza FLUENT 14 September 6, 2015 17:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
UDF problem in multiphase model Amir Khodabandeh FLUENT 1 March 13, 2009 09:43
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 13:05
