Writing data from DEFINE_DPM_SPRAY_COLLIDE
Old   August 3, 2009, 20:33
Angry Writing data from DEFINE_DPM_SPRAY_COLLIDE
Hanz is on a distinguished road
Hi All.
I'm currently creating a UDF using the Macro DEFINE_DPM_SPRAY_COLLIDE. Within this code I generate a random number. It turns out that even if my source file simply contains the fprintf commands, I'm unable to write data. However, when using the exact same fprintf commands in a seperate source file using DEFINE_DPM_SCALAR_UPDATE I was able to write a file showing the displacements, velocities, Particle IDs etc.
Any ideas on how I could export data from DEFINE_DPM_SPRAY_COLLIDE would be really appreciated.
Cheers,
Hanz.
Hanz is offline   Reply With Quote
Old   August 4, 2009, 11:21
Micael
Micael is on a distinguished road
Make sure you understand when your function is called. I never use this one, but you can add this line of code to check when your function is executed:
Message("DEFINE_DPM_SPRAY_COLLIDE executed!");
If the function executes, you will see the message on the console.
That helps me some times to track such problems.
Have a good day.
Micaël
Micael is offline   Reply With Quote
Old   August 4, 2009, 17:20
Micael,
Thanks for your reply. The Message has proved really useful.
Best regards,
Hani
Writing data from monitors L3munoz FLUENT 0 July 24, 2009 06:27
Writing profile data at transient heat transfer analysis Ama FLUENT 0 July 5, 2009 08:35
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Writing a transient data fileld ant CFX 0 October 20, 2002 13:19
Writing grid and velocity data to files Mehul Kinariwala FLUENT 2 October 4, 2000 10:26
