fluent udf problem for 3d case
Old   July 28, 2009, 08:25
Default fluent udf problem for 3d case
Soumya Ranjan Sahu
srsahu is on a distinguished road
hi, i am from iit madras.(soumyasahu1986@gmail.com)
i have a problem for running the iteration with the following code for flow past a circular cylinder(3d).
i compiled ,hooked,but when i am iterating it shows problem like
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
i have 3 gb ram system.can any body tell where is the the problem.
here is the udf for non linear k-w
srsahu is offline   Reply With Quote
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 08:51
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 07:49
Couldn't re-open a fluent case J.Gimbun FLUENT 3 May 15, 2006 04:48
I have problem of UDF with turbulent premx source. Z FLUENT 0 February 16, 2005 04:34
